Case Mod - In Progress KiiYzOo_Skeleton
Discussion in 'Project Logs' started by KiiYzOo, 11 Aug 2011.
  1. KiiYzOo
    KiiYzOo What's a Dremel?
    11 Mar 2011
    Hey guys, after my last build, I decided that I wanted to have a build that was a little different to other projects out there, so I decided to get a skelly :D
    So my new skelly arrived at around 20 past 11 this morning, so I've had most of the day to play with it :clap:
    I'll start off by saying that this is an awesome case :D I love the finish,build quality and overall looks of this amazing case :D
    case after first unboxing it, it looks like it's dark outside but that's just because of the flash :p
    Motherboard fitted to the removable motherboard tray :)
    This case is really easy to work with, because of things like being able to slide the part that holds all the components :)
    This is where the pump is, although it is the other way round just now, and that is just twisting of the pipe :p
    Love this button :p
    case before leak testing
    need some more tubing, as that tube from the rad to the cpu just fits with a little kinking
    filling the loop
    loop filled, leak tested and bled :)
    I had to bend a couple of fins on my graphics card's heatsink, I did this earlier and didn't realise, and had to bend at least five fins back into shape :rolleyes:
    Skelly in her new home, sssshh she's scared :p
    There she is :p
    That's all for today, but I'm planning to:
    paint everything that is black, orange
    get some orange fluid
    get some uv or orange led strips
    either watercool my 460 or upgrade and watercool that card
    fit my second rad
    light up my res
    maybe upgrade my cpu and motherboard
    braid my psu :D
    maybe other things but I can't think just now :p
    specs:
    i3 540 @ stock just now, my motherboard is very annoying for overclocking :rolleyes:
    msi p55a-g55
    msi cyclone gtx 460 768mb
    xfx 650w xxx modular psu
    corsair xms3 1600mhz
    1tb hitachi hard drive
    watercooling specs:
    EK HF supreme waterblock
    EK compressions
    EK 250mm res
    Hardware Labs Black Ice® GT Stealth Lite 360mm Triple Radiator
    Phobya DC12-260 12v pump
    3x Xigmatek XLF 120mm LED Case Fans
    Hope you guys enjoy :D
  2. KiiYzOo
    11 Mar 2011
    ***WARNING - 26 pics inbound***
    So, over the last couple of days I've been working on my revised loop :D
    I finished this morning and I just uploaded the pics now, enjoy :D
    that was it for the night, as going to see Al Murray at the festival, I didn't have much time left :p
    before filling
    after filling and leak testing
    finished bleeding and decided to take more pics :)
    side panels with holes drilled to allow for the rad brackets
    now back in place
    had to put the 460 in the lower slot so I didn't have to cut the case
    and that's it, thanks for looking guys :D
    p0Pe likes this.
  3. Gentleman_Dingo
    Gentleman_Dingo What's a Dremel?
    30 Aug 2007
    !!! I've never seen an Antec Skeleton case before. I'm so bloody used to plain square box cases, I would have bought this one instantly.
    Are you doing any structural modifications or centering on the water cooling? What are some of your plans? Give us some teasers!
  4. KiiYzOo
    11 Mar 2011
    thanks :D
    thinking about painting the front fan, bitfenix fans on the ek rad, and I'm getting a fan controller which I'm gonna paint orange, I'm also probably gonna get some uv and orange led strips and also light up my res with uv leds, get some orange bitfenix extensions, and maybe more as I go along :p
  5. Gentleman_Dingo
    30 Aug 2007
    Sweet! Mod on my friend and keep us posted!
  6. KiiYzOo
    11 Mar 2011
    thanks, will do :D
  7. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    This is awesome man! I love it!
  8. KiiYzOo
    11 Mar 2011
    thanks m8 :D
    Jake123456 likes this.
  9. Jake123456
    Jake123456 Surprise!
    25 Jan 2011
    Looks awesome, can't wait for the next update ^.^
  10. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Came here from that other loser's worklog :D
    LOoks good. 1st time I see a skeleton watercooled
  11. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Fine work man! Glad to see another one take on the antec skeleton. Never like that case to much myself, but with watercooling you have made it look alright:D
    I have a few suggestions:
    -Make a bracket for the reservoir
    -Keep a good eye on those EK blocks. The nickel might start to were off since the EK nickel blocks are horrible.
    -Make your reservoir stand vertically. It will make it way easier to bleed, and will make sure that the air dont get pulled round in the loop:)
    :clap:
  12. PabloFunky
    PabloFunky What's a Dremel?
    19 Sep 2010
    You sure you dont know that puttsy guy, this has been great for views on your worklog :D.
    Thats a fine job of a skeleton case, was never a fav case of mine, but your making it look nice.
    White and Orange rules.
  13. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Forgot to + rep :p Just because i can :D
  14. StonieX
    StonieX What's a Dremel?
    23 Dec 2003
    I love the colour combination and the "naked" concept :thumb:
    how pOPe said, brackets for the res would be nice :dremel:.
  15. Jake123456
    25 Jan 2011
    Sub'd and Rated the thread for a confidence boost (Y)
    Mod on dude (Y)
  16. KiiYzOo
    11 Mar 2011
    thanks guys :D
    I have brackets that were supposed to be 50mm brackets, but are too big for some reason, also it is quite hard to mount the res with a bracket, but keep most of it hidden :rolleyes:
  17. Jake123456
    25 Jan 2011
    Mount it on the outside?
  18. KiiYzOo
    11 Mar 2011
    I prefer it where it is :p
  19. Jake123456
    25 Jan 2011
    Would look pretty awesome there :3
  20. KiiYzOo
    11 Mar 2011
    where? :p
