Kill this, PLEASE
Discussion in 'Hardware' started by Guest-44638, 14 Jul 2019.
  1. Guest-44638
    Guest-44638 Guest
  2. Vault-Tec
    30 Aug 2015
    As I said in PM it is the same tech, only better. So yes, I would say you could apply the QVL from Zen 1000 and 2000 series and be OK.
    The reason B die is better, dude, is because it's well, better. I know with the 1000 and 2000 series it was very important to clock your ram to at least 3000mhz because Infinity Fabric runs at the RAM speed which made a big difference. Like, 20% over running 2133mhz RAM.
    I know that with Zen 2 they have increased the cache which apparently alleviates that problem but I have yet to see any concrete evidence. No one has tested it at slower RAM speeds, and I have a 16gb 2666 kit I wanted to use. If I find, however, that I have to buy RAM I will stay where I am at for now. Both rigs I have do what I want them to so it would be daft spunking money down what could be a expensive drain.
    Guest-44638 likes this.
  3. yuusou
    yuusou Multimodder
    5 Nov 2006
    Why 32GB of RAM? Why m.2? How will you be taking advantage of these?
  4. Gareth Halfacree
    4 Dec 2007
    My last upgrade was a 2700X, B450, 32GB of DDR4-3000, and a 1GB M.2 NVMe. It's pretty durn nippy, and 'cos I'm on a B450 board I can drop in a Zen 2 chip in a few years time for a cheap upgrade.
  5. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    M2's current prices make them very attractive as well
  6. Mr_Mistoffelees
    26 Aug 2014
    Unless you actually need more RAM, why not go for 16GB plus an nvme M2 drive?
  7. GeorgeStorm
    16 Dec 2008
    You can always buy a single stick of 16gb with the option to add another in later if you need it. That's what I did with my current daily (but with 8gb sticks) and have yet to actually get another stick haha.
  8. adidan
    25 Mar 2009
    The max version of that board will be out soon, probably best to pick one of those up with the increased BIOS size.
  9. adidan
    25 Mar 2009
  10. Anfield
    Anfield Multimodder
    15 Jan 2010
  11. Gareth Halfacree
    4 Dec 2007
  12. adidan
    25 Mar 2009
    They're supposed to be replacing the current line up, aledgedly at the same price point.
  13. adidan
    25 Mar 2009
    Out of interest, why did you settle on an X470 and not a B450? You started with a B450 and then the X470 became a definite?
  14. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    I think its possible but you are going to have to be patient and watch sales like a hawk
    I did that took like 4 months but it gave me plenty of time to mod my case lol
  15. silk186
    silk186 Derp
    1 Dec 2014
    I strongly recommend an M.2 drive. I upgraded and notice an improvement in system usability. Even running large work documents with referencing software was significantly improved over SATA based SSD.
    I'm looking into upgrading from 16GB to 32GB as prices are coming down, but I'm not sure I really need it.
  16. Vault-Tec
    30 Aug 2015
    Do it whilst you can. Ram prices are so volatile.
  17. yuusou
    yuusou Multimodder
    5 Nov 2006
  18. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    The msi b450 boards are a decent choice just do not get too heavy handed with overclocking as there is only 1 vrm heatsink on the gaming + boards
    Mine has been very happy but I'm not maxing things out ( 8 core 4ghz 2700 at 1.3 volts)
    If I put it in what I call "asshole mode" 1.4 volts 4.3 something ghz its fine but everything gets toasty (for not a large gain)
  19. silk186
    silk186 Derp
    1 Dec 2014
    I'm wondering if they will drop further. Prices in the used market have not really dropped in line with recent sales.
    RAM is something I'm happy to buy used.
  20. Vault-Tec
    30 Aug 2015
    Second one doesn't work.
