News Killer gaming WiFi adaptor released
Discussion in 'Article Discussion' started by arcticstoat, 1 Mar 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. mi1ez
    mi1ez Modder
    11 Jun 2009
    I can't see them fulfilling many, if any, of those promises...
  3. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Oh but come on. None of these "Killer" items have ever worked in any way. It's a massive ripoff.
    /rant.
  4. wyx087
    wyx087 Multimodder
    15 Aug 2007
    why don't they bring out a router? that's usually the root of most client-side lags: cheap ISP routers that don't have QoS.
  5. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    What sort of gamer (who has the choice) plays on wifi anyway?
  6. Fanatic
    Fanatic Monimidder
    4 Jun 2010
    If there is a choice no one plays on wifi - IF (and its a big IF) they can overcome/improve the inherent issuse with wireless in it current form they may sell a few, but I wouldnt be picking one up. Have no doubt it will probably cost the same as a small country's GDP too!
  7. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    Fixed :D
    wyx087 likes this.
  8. EvilRusk
    EvilRusk What's a Dremel?
    23 Jan 2006
    Uh, I use wifi and it works fine for me playing games!
    It's all down to setting things up properly. I use a decent wireless-N usb dongle positioned clear of obstacles, choose a clear channel so no interference from neighbours and rarely have any trouble at all.
    In my experience the quality of connection is affected more by how good your ISP is, whether there is congestion anywhere along the route to the server and if anybody at home is downloading.
    I do agree that producing a killer wifi card is a waste of time without sorting the router as well as the connection is only as good as the weakest link.
  9. Tokukachi
    Tokukachi Minimodder
    20 Jun 2007
    Are these guys a sub-division of Monster Cables?
  10. Evildead666
    Evildead666 What's a Dremel?
    27 May 2004
    Exactly what I was thinking. ;)
  11. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    Prioritising gaming traffic is all well and good but how much of a difference does it really make? Little to none from what I've seen. If you really care that much about your ping then you should get with an ISP like BE who prioritise gaming traffic over their network. That will benefit you in a real sense, rather than in an imaginary sense.
  12. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    Oh great timing, I just ran out of my last bottle of snake oil.
    I game wirelessly and have no difference in pings no extra lag from when I used ethernet cable.
  13. Claave
    Claave You Rebel scum
    29 Nov 2008
    Article now with actual images of the WiFi unit!
  14. faugusztin
    11 Aug 2008
    Pocket-killer! No other use for it :).
  15. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Were they comparing it to a 802.11g adaptor by chance?
  16. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    Amazing...five times faster. So in other words, they'll be able to get my transfer speeds to be faster than my routers and cards are rated at...
    Once the wifi adaptor is working normally, it's ALL in the router. We know that...they're trying to fool the wrong crowd, methinks.
  17. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    actually I have noticed the n cards are faster than the older b-g
    for example in chop tests against a wireless g.. we used a popular wireless card with high wattage- it ran a 40 second chop
    same distance we ran a card that was 4 times weaker in wattage but was the newer n type, using the same 9 dbi antennae- did it in 12.. same 2.4-2.5ghz range so it's not using the higher frequency either
    with 18 dbi directional of course even better
    so they may have a claim, but they aren't the only ones.. I ended up amping the sucker and probably have the best setup for wireless that would blow the socks off this card- for a lot cheaper too
    thing is I maybe plan to sell these as kits.. so I can't be giving up the exact details as I normally would (you guys know me- give up all the secrets and if someone is being a fanboi they get the pumpkin to the face :blush:)
  18. ch424
    ch424 Design Warrior
    26 May 2004
    Of course they're faster. They use double the radio bandwidth, and use MIMO.
  19. thehippoz
    19 Dec 2008
    same freq
  20. tad2008
    tad2008 What's a Dremel?
    6 Nov 2008
    Review?
Tags: Add Tags
