My tubing seems to kink alot. I thought I'd fixed it by making the tubing long, but that doesn't appear to have helped afterall. I've been trawling through various online stores and can't seem to find the little spring things that you wrap around tubing to prevent springs. Can anyone point me in the right direction?
BTW if your tubing kinks a lot, you may have to re-plan your watercooling loop. If you do it right, there should be no sharp enough bends to cause any kinking. Also always get the thicker wall (3mm) tubing for structural integrity.
