Scratch Build – In Progress Kitchen Sink computer.
Discussion in 'Project Logs' started by Cheapskate, 29 Nov 2023.
  1. Darkened
    Darkened Minimodder
    28 Feb 2004
    @Cheapskate Indeed it's been a while, but I'm back at it for a change, so I'll cover you for a while :hehe:
    Sad to hear about the hurricane damage (and the contractors). Hopefully you'll get things sorted on that front.
    Cheapskate likes this.
  2. Cheapskate
    13 May 2007
    Something woke me up early. -Well, This area went from "livable forest" to urban hell, and my property still has trees. I inherited ALL the birds. They sure can yell.
    I don't have any 'sink' progress, but there was something I've been picking at slowly since December:
    -This winter, GwassGween sprung an absolutely odd leak, and I should report this so no one else makes this mistake. That dent in the pipe is where the O-ring seated and pressed against the tube. I had trouble earlier with plasticizer in the Tygon tubing attacking the softer extruded plastic, and it looks like it made this tube soft enough to deform. On a day of a freeze, it got cold enough inside to shrink everything and cause a massive leak.
    So I have parts of GG's internal covers off and regular tube installed. Parts are running loose and calling for tinkering.
    -Shout out to @SaaintJimmy :D He inspired me to play around with fiber optics long ago. I wanted to add some subtle light to GG. -cue blurry pic of tiny holes drilled behind fins in GG's GPU cover. I used small plexi tube to meet four bits of fiber to an led. Silicone glue was used for the clear bits, and tub sealant because it was handy.
    -Very subtle in daylight.
    -Not crazy bright in the dark. :thumb: Yes, it's pink. I have 100 pink LEDs to burn through.
    The result would be a lot stronger on frosted UV plexi with UV LEDs. Here with my high polish, it shoots straight through like a laser.
  3. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    You'll make a combo with pink and UV led ?
  4. Cheapskate
    13 May 2007
    @Dot_Kappa -Sorry for the slow reply. No. I was just suggesting this would work better on a reactive plastic.
    pccustom likes this.
