Food & Drink Knife sharpener
Discussion in 'General' started by Cerberus90, 25 Dec 2017.
  1. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Hey bit-tech,
    Merry Christmas everyone.
    Fed up of having blunt and notched knives in the house, want to get a good sharpener.
    Suggestions? Thinking up to about £20. None of the knives we've got are super duper ones, they just all gone blunt.
    Cheers
  2. Kronos
    Kronos Multimodder
    6 Nov 2009
  3. David
    7 Apr 2009
    I just use a two grade whetstone.
    Cerberus90 likes this.
  4. legoman
    legoman breaker of things
    28 Feb 2010
    Been using a Lansky Blade medic for years still doing me well.
  5. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
  6. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    Whetstone from a catering supplier: £15,--. Don't overcomplicate things.
    Byron C, Cerberus90 and David like this.
  7. VipersGratitude
    VipersGratitude Multimodder
    4 Mar 2008
    This is bit-tech. Use a Dremel.
    RedFlames likes this.
  8. Cerberus90
    23 Apr 2009
    We've got an bench grinder in the shed I could use, but I know I wouldn't get a very straight edge on it, :D
    Think I'll get a whetstone.
  9. Byron C
    Byron C AKA “Sticky Equilibrium” on weekends
    12 Apr 2002
    Get a honing steel as well as a whetstone - often incorrectly called a sharpening steel, or simply a steel. You won't - or shouldn't - use a whetstone very often, only when you need to put a new edge on the blade. Maybe once or twice a year at most, depending on how hard it gets used. A honing steel, on the other hand, should be used as often as possible.
    I've got a set of kitchen knives made of German X50CrMoV15 steel (see here http://zknives.com/knives/kitchen/misc/articles/kkchoser/kksteelp2.shtml for info) and I use a honing steel every single time I use one of them - it makes such a huge difference to the blade. I haven't even opened the packaging on my whetstone, the knives still feel just as sharp as when I bought them ~6 months ago.
    I'd really like a kitchen knife made of high-carbon steel, but I can't justify >£80-£100 on one single knife! :grin:
  10. Krikkit
    21 Jan 2003
    I know the knife obsessives will hate it, but I use a cheap stick-on V-form sharpener in the kitchen, brilliant purchase.
  11. Nexxo
    23 Oct 2001
    Byron C likes this.
  12. Krikkit
    21 Jan 2003
    :D
    To be honest it keeps the knives sharp - I'm only using a set of Sabatiers, the handles will fall apart before the blades are ruined.
  13. Cerberus90
    23 Apr 2009
    Is the honing steel the round bar that looks like a file that you get with some knife sets? If so we've got one of those, but the knifes are so notched and crappy that you'd be going for hours with it, :D
  14. Byron C
    12 Apr 2002
    That's the one. Once you've sharpened a knife with a whetstone (or whatever) you shouldn't need to sharpen it again for a long time if you use a steel regularly. The steel doesn't actually "sharpen" - i.e., grind away material to create an edge. It straightens all those little burrs and bends that you can't see on the edge of the blade: http://kitchenknifeguru.com/honesandsteels/whats-a-honing-steel/. It does keep the knife sharp, but it doesn't do it by grinding material away.
    I bought a knife sharpener a few years ago because I was sick of using blunt knives. Then I got sick of having to sharpen my knives all the time because they couldn't hold an edge. Then I realised what I was doing wrong :winking:.
  15. dosmel
    dosmel What's a Dremel?
    31 Jan 2018
    I have the Spyderco Tri-angle sharpmaker that I got on amazon. Been using it for years.
  16. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    The Spyderco sharpmaker is still the king; any idiot can put a razor edge on a knife with one.
    I've been sharpening knives with every method going for 14 years now and I struggle to match the edge I can get with the sharpmaker.
  17. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    I got one of the totally-not-a-Lansky's from Massdrop to regrind a set of awfully abused knives, worked well enough.
  18. Gol.D.Rogers
    Gol.D.Rogers What's a Dremel?
    27 Feb 2018
    whetstone, better if two grade, its best way to sharp any knife. Some sh*t like APEX sharpener its a bad and expensive method.
  19. ElThomsono
    18 Mar 2005
    I never recommend whetstones, they're beyond most people's capabilities and many don't have the desire to spend the time learning.
    Stick with the easy wins I say!
  20. Gol.D.Rogers
    27 Feb 2018
    Yes its fast and easy. Good choice!
