Hardware Lamptron FC5 V3 Fan Controller Review
Discussion in 'Article Discussion' started by Meanmotion, 23 Aug 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. mi1ez
    mi1ez Modder
    11 Jun 2009
    I prefer this to either the CW611 or the NZXT Sentry Mix 2. Best looking (IMO) and nice and simple.
  3. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    Did I miss it or does the review mention what it's like to actually use? Can you use the dials to select a temperature with fans controlled automatically or is just a rheostat/pot with results read-out?
  4. Combatus
    16 Feb 2009
    It's a manual fan controller - did mention this - ie you need to use the dials to adjust fan voltages ;)
  5. ChaosDefinesOrder
    6 Feb 2008
    thanks, seems it just didn't fully sink in!
  6. Bokonist
    Bokonist What's a Dremel?
    2 Mar 2011
    Love the look of this, shame it would be obscured by the fridge door on my Fractal Design R2. Has anyone here modded a window onto a Fractal door?
  7. himaro101
    himaro101 What's a Dremel?
    31 Mar 2010
    are there any fan controllers for rotated ports (like the Corsair Carbide 540 for example) ?
    I'd love to have a controller of this quality but rotated so i didn't have to rotate my head to read it.
  8. keir
    keir S p i t F i r e
    5 Oct 2003
    Might be stupid but can you use any fan with this? (correct pins of course)
Tags: Add Tags
