News Lancool gets new, more aggressive cases
Discussion in 'Article Discussion' started by Baz, 9 Mar 2009.
  1. Baz
    Baz I work for Corsair
    13 Jan 2005
  2. azrael-
    azrael- I'm special...
    18 May 2008
    It's facepalm time!
    All the hideous case designs coming out recently make me wonder if we've entered the "Year of the Fugly Dragon" or something...
  3. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    *Another one bites the dust*
  4. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    While the design isn't that bad I still prefer the blank canvases Li-Li normally builds. Although they started screwing things up as well, recently...
  5. TomH
    TomH BELTALOWDA!
    28 Nov 2002
    To be fair to Lian-Li, if they can sell that NAS/ITX box (with the ITX board) at a reasonable price it'll best the Supermicro model I was looking at, easily.
    Just out of interest... What's the desktop/HTPC case under the NAS case, or is it nothing new?
  6. Guest-23315
    Guest-23315 Guest
    I like the NAS box..
  7. Jenny_Y8S
    Jenny_Y8S Guest
    So is it a mini-itx case or not? If it takes full sized ATX mobos then surely it's an ATX case (OK a small one). If it's a mini-itx case then surely it won't take anything larger!
  8. walle
    walle Modder
    5 Jul 2006
    That Lancool case looks like an improved version of the Antec Three Hundred, judging by the pictures it looks better (design wise anyway).
  9. jhanlon303
    7 Sep 2006
    I read the article as meaning the case would accept ATX sized PSUs, which it appears to do.
    Single PCI slot in the right position and not enough space on the other side of the I/O for much. It's ITX small.
    john
  10. perplekks45
    9 May 2004
    I think technically Jenny's right. If it accepts anything bigger than Mini-ITX it's not a Mini-ITX case.
    I'd still say it's small enough to be advertised as one because that's the market it'll compete in.
  11. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Why don't all those case makers look ahead and make some room for water cooling. I just love the bottom part of the Silverstone IT7, you can fit anything in there. one 360rad, one 240rad, pumps etc, Just a little suffering coling in the upper compartment and the two 80mm fans in the back, it also costs a fortune... Someone make a case with in the lower part room for WC, upper part like recent midtower cases with a nice sidewindow. And there presto, instant succes!
  12. Nicb
    Nicb Let's discuss among ourselves
    12 Nov 2008
    ??........... I like the width of the cases. Thats it, their ugly and bland, hard to pull off both. What an achievement.
  13. Slyr7.62
    Slyr7.62 «ŚŁÂŶÈŘ»
    14 Dec 2007
    Well, I'd take LL's mid-tower over the Antec 900/902/1200, depending on the price. :p
    Still has plastic on the front and top......*face palm*.
  14. Guest-16
    Guest-16 Guest
    It's a mini-ITX case that takes "ATX" PSUs - as in standard size and mount. Although I think it might be limited to mATX in half depth - I'll have to check when we get one in.
    The HTPC cases underneath are nothing new afaik - they are already available.
    Obi - TJ07 costs a LOT to tool.
  15. Rocket_Knight64
    Rocket_Knight64 Minimodder
    12 Feb 2009
    While they are ugly, its not as bad as the other recent offerings. And the internals seem nicly layed out although:
    -Its nice that somone has finaly realised an 8'th pci slot would be usefull, they have not put a blanking plate there...
    -Why dont they just fully cut a hole behind the cpu so its usefull (like CM)?
    I sometimes get the idea that case and motherboard makers dont actualy use PC's. Some of the flaws and nice touches are so easy and obvious...
  16. jhanlon303
    7 Sep 2006
    @Bindi
    Do you think the mini-ITX case will make it to the colonies?
    I have a couple previous build owners that like the looks of this case.
    john
  17. dyzophoria
    dyzophoria Minimodder
    3 May 2004
    i also like the NAS box :)
  18. Guest-16
    Guest-16 Guest
    Depends what your current distribution is like?
  19. tonschk
    tonschk Minimodder
    31 Jul 2008
    Overall the case is OK , but the toolless design for the PCI slots is silly , to be honest for me is really not a problem to turn a screw every two years to install a new video card , therefore I think the silly PCI toolless design is a nonsense and useless
  20. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
Tags: Add Tags
