Motherboards Laptop socket repair problem
Discussion in 'Tech Support' started by nukeman8, 21 Oct 2011.
  1. nukeman8
    nukeman8 What's a Dremel?
    24 Jul 2008
    Im probably going to sound very stupid but im trying to do a power socket repair on a presario f700 laptop.
    I stripped it down, located the socket and then tried to solder it off. No matter what i do i cant get the existing solder off, i have tried 3 different soldering irons and i just feel like im missing something, help? :confused:
  2. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    i too get this problem, i use a temperature controlled de-soldering iron, set @ 450 and still cant get some off, in which case, i end up using snips to destroy the outer metal casing, which then makes it easier to remove.
    WARNING using such a high temperature can cause damage, be warned.
  3. gerardmcmanus
    gerardmcmanus What's a Dremel?
    11 Oct 2011
    have a look at this
    http://www.kpsec.freeuk.com/solder.htm
    there is a bit near the bottom which says:
    I seen this being done on a youtube video before, seems to work quite well, but not tried it myself, I have had the same issue in the past it is a pain. Just make sure you don't touch the board with the iron while you are de-soldering or you can bugger the board.
  4. Bungletron
    Bungletron Minimodder
    25 May 2010
    You are using a solder sucker right? I was desoldering some led screens off some VW Golf clocks (replacement mph clocks for a Jap import that had kph clocks, nothing dodgy) the other day and it was irritating and intricate work because the pcb holes are very small. I think I could have benefited with a slightly more powerful iron (mine was 18W I think), I had to melt the solder, move the pin to the furthest edge of the hole with the iron and place the sucker as much over the whole as possible to get good results, it took ages.
  5. RichCreedy
    24 Apr 2009
    the problem solder joints aren't melting in my case, normally because all the heat sinks off somewhere like the big metal cover on some sockets, or the big piece of copper they are soldered too
