Other Laser/cnc cutter of plywood
Discussion in 'General' started by Revil0, 22 Feb 2020.
  1. Revil0
    Revil0 99% lurking
    21 Jan 2011
    Hi All,
    I'm looking to get a mould and template cut from 16mm and 3mm ply respectively (approx 40x30cm). I'd normally do this with bandsaw and finish to the line by hand but plywood isn't the nicest material to work with...
    Any suggestions for companies or (members!) that could do this kind of thing?
    Thanks!
  2. Spraduke
    Spraduke Lurker
    23 Sep 2009
    See if you have a fablab near you. Can rent CNC and laser cutter by the hour. They'll even train you in its use.
  3. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    @Revil0 Sent you a pm mate. I might be able to do it on my CNC router.
