I am sure someone here has tinkered with it so: My problem is I installed Winamp, installed LCDriver 1.0 and how do I get winamp to use the LCDriver plug-in? I cant see the plugin under Winamps plugin selection menu unser preferences. What dir do I point it at? Or do I need to copy a file at location X to location Y?
If you've installed the plugin fine (to /winamp/plugins/) you need to go to Winamp -> Plugins -> Visualisations and it should be there, just need to press start. If you want it to work all the time, goto the general plugins options and tick Start Visualization Plugin At Startup (or some likes - I'm doing this from memory) HTH |H|
and once youve tried that, use the winamp plugin I pointed out on http://www.icehardware.net/reviews/lk20425/2.shtml
