Electronics LCD electronics help!
Discussion in 'Modding' started by Balder, 26 Apr 2004.
  1. Balder
    Balder Calmer than a monk on morphine
    4 Jul 2003
  2. mattg2k4
    mattg2k4 What's a Dremel?
    4 Jun 2003
    First, it is often fairly difficult to get proprietary equipment like this working in a useable way.
    Do you have the specific model number? Even if you do, you will need a bit more than the pinout, you need to know something about the instruction set to communicate with it.
  3. Alekoy
    Alekoy Ostekake!
    28 Dec 2003
    hmmmm...
    That is the same thing as the one that stands on the desk at my bank,
    Isn't there a standard data plug on the end? i mean.. it is somehow connected to the tellers computer.. maybe via LAN?
    You know that thescreen is in a touchy mood?(meaning touch screen)
