LCD Screen for Gaming
Discussion in 'Hardware' started by G4m3R_X3r0, 4 Mar 2005.
  1. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    Ok guys you havn't let me down before, I need a good LCD Screen that is good for gaming as well as general purpose. I'm looking for a 19", some where around $350 USD. Right now i'm using a NEC MultiSync FE700+ that is on it's last legs, and help and or advice would be great!!!!
    EDIT: Also Black color and no TV Tuner, perferably with a DVI Connector. And i could careless if it's not name brand, I just need something good that works and will take up less space on my desktop.
  2. ehrnam45
    ehrnam45 What's a Dremel?
    5 Jul 2004
    wow, good luck unless you find one refurbished or used. I found a 19" philips at newegg.com (12ms, no speakers/tuner, VGA in only) for $430-ish If you want low response time and DVI together, you're looking at $500 and up retail.
  3. user0001
    user0001 What's a Dremel?
    8 Sep 2004
    Well, L90D is perhaps the best budget 19 around, but no DVI and some say that its Dell purple :confused:.
  4. olv
    olv he's so bright
    23 Sep 2002
    yeah, i think your budget is unrealistic. you'd be looking at £350 for a decent gaming 19" let alone $350 dollars. i think the saying " you get what you pay for" really holds strong with tfts atm. you need to pay for performance.
  5. user0001
    8 Sep 2004
    Well, the L90D has received excellent reviews. But this has become commonplace for Hyundai's LCDs (L70S, Q17, now L90D). It can be done, but right now there arent many low-latency 19s (as apposed to 17s).
  6. Guest-16
    Guest-16 Guest
    Remember 19" CRT = 19" tube, not screen size. The actual screen size will be closer to low 18" something, whereas a 17" TFT = full 17" diagonal width, so you wont loose as much space as u think.
  7. Hiren
    Hiren mind control Moderator
    15 May 2002
    Yeah what Bindi said. 17" is probably the best thing to go for. As far as specs goes the new Shuttle 8ms is screen is reportedly one the best for gaming.
  8. G4m3R_X3r0
    3 Sep 2004
  9. user0001
    8 Sep 2004
  10. Hiren
    15 May 2002
    G4m3R_X3r0 -
    So no that's not it.
    Link . That's the one.
  11. Guest-16
    Guest-16 Guest
    Ive used the 16ms one before and it was good, but 8ms is always better ;) The temperd glass is seriously sweet and stops people poking the screen :thumb: and makes it easier to clean! :thumb: :thumb: :thumb:
  12. cysus
    cysus What's a Dremel?
    14 Apr 2004
    8ms grey to grey response time is not an accurate response time, which by definition is the time it take to go from black to white to black again.
  13. Blackfish23
    Blackfish23 Minimodder
    13 Oct 2004
  14. Veer
    Veer What's a Dremel?
    3 Dec 2004
    have a look at
    samsung Syncmaster 710v 17". One really cool lcd. Might have 19".
  15. G4m3R_X3r0
    3 Sep 2004
  16. Fibbles
    Fibbles What's a Dremel?
    22 Apr 2004
    Viewsonics are quite nice. I want this one: http://www.newegg.com/app/ViewProductDesc.asp?description=24-116-285&depa=1
    I have a 17" Hitachi CLM174SWXB 16 MS response time and I love it, but I want a bigger one. When I have enough saved up, I'm hoping that there are 12 and 8 MS ones already established and relatively cheap.
  17. G4m3R_X3r0
    3 Sep 2004
    I don't really need one that big... still nice tho
