Disaster Learning AutoCAD for CNC/Laser Cut
Discussion in 'Modding' started by yeknom, 3 Jun 2008.
  1. yeknom
    yeknom What's a Dremel?
    23 Apr 2008
    Hello bit-tech,
    Does anyone have any good tuts for learning AutoCAD? I want to learn some basics for CNC/Laser Cutting.
    Thanks a million
  2. Teyber
    Teyber ******
    18 Mar 2007
    lots of people use solidworks for cnc, well cnc milling at least. check youtube, i think there should be quite a few tutorials on the actual software. but i know a couple people did a autocad series on youtube...
    regards
    edit:
    since this is not a machining forum, you might not get the best answers... if you have more questions you might want to check out this forum:
    www.cnczone.com
  3. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Check out your local library, they might have books on the in's and out's of AutoCAD
  4. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    most CNC cutters use a proprietary system for the actuall CAM and then of course .DWG files are sort of an industry standard for CAD files between systems. Any system that can sketch a 2 dimenionsal file and output it as .DWG can be used for laser cutting. At work I have autocad and solidworks and sketchup, I used to use a waterjet software for 2d pieces because it was soo incredibly nice and fast.
    I guess I'm rambling, anyways autocad is sort of a beast, it's not my preferred cad program, solid works or inventor could do this and they are a lil more user friendly. Sketchup is free and code do it albeit it's somewhat limited
  5. idzver
    idzver What's a Dremel?
    14 Jun 2008
    try lt instead of full autocad, but autocad should have its own tutorial that walks you through all the basics, which is all you would need for cnc work anyway.
    should be easy enough to learn in about an hour or so.
