Other Led Strip Wont Dim?
Discussion in 'Hardware' started by Zentaaa, 9 Sep 2014.
  1. Zentaaa
    Zentaaa What's a Dremel?
    23 Jul 2014
    Just bought this led strip at scan..
    And I need to dim it as it is too bright! I have tried to run it at 5v and 7v but it doesn't turn on at all?
    Is this led strip just a simple 12v or off?
    Thanks
    Mods if im in the wrong section please move me! Cheers :thumb:
  2. Teelzebub
    27 Nov 2009
    7v is probably to low for it.
  3. Zentaaa
    23 Jul 2014
    Really? What can i do?
  4. Guinevere
    Guinevere Mega Mom
    8 May 2010
    My understanding is that you can't dim an LED strip simply by lowering the voltage. The regulators and doodads within the strip aren't happy.
    You'll probably need something like this: (I have no idea if this exact solution will work for you!!)
    http://www.amazon.co.uk/LEDER®-WIRE...=1375113984&sr=8-1&keywords=led+lights+dimmer
    That should dim the strip by rapidly swathing the LEDs on and off, this is how LED dimming generally works.
  5. Zentaaa
    23 Jul 2014
    Dont worry boys i have sorted it, gunna get a remote control phobya strip! Cheers for the input boys!
  6. Zentaaa
    23 Jul 2014
    Actually one more question.. Will this work to dim my current led strip?
    Thanks
  7. Kronos
    Kronos Multimodder
    6 Nov 2009
    I have a couple of these things, bought mine with long light strips off Ebay and they certainly will dim the supplied LED's. So yes it will work.
    This is what I bought.http://www.ebay.co.uk/sch/i.html?_f...1.TRC1.A0.H0.XRGB&_nkw=rgb+led+strip&_sacat=0
    You can cut the strips to a desired length, change colour, dim, flash ETC ETC.
  8. Zentaaa
    23 Jul 2014
    Just been looking at the ir remote controller and my phobya flexlight connects via a 3 pin fan header but this ir remote controller uses some odd connector I have never seen before haha! Im so confused :s
  9. Kronos
    Kronos Multimodder
    6 Nov 2009
  10. Zentaaa
    23 Jul 2014
  11. Kronos
    Kronos Multimodder
    6 Nov 2009
    Hmm that is odd as they are both the LED strip and the controller are Phobya.
    As the controller has the 4 cable connection I would suggest picking yourself up some light strips from Ebay as they use the same connection as your controller.
  12. Zentaaa
    23 Jul 2014
    Any way I can bodge it up because I have spent way too much on led strips recently lol
  13. Kronos
    Kronos Multimodder
    6 Nov 2009
    I don't think so as one is 3 wire and the other is for so you would lose something along the way.
    Look bung me your address by PM and I will send you these lights.
    Just the lights though I am keeping the remote ETC.
    Margo Baggins likes this.
  14. Zentaaa
    23 Jul 2014
  15. Kronos
    Kronos Multimodder
    6 Nov 2009
  16. Zentaaa
    23 Jul 2014
  17. Kronos
    Kronos Multimodder
    6 Nov 2009
    LED's posted.
    notmeagain likes this.
  18. notmeagain
    notmeagain Minimodder
    29 Jan 2009
    Much love here.
    +1 to you
  19. Kronos
    Kronos Multimodder
    6 Nov 2009
    Have the LED's arrived yet?
  20. Zentaaa
    23 Jul 2014
    Yes :D Thank you so much :)
