Electronics Li-Po battery pack charging
Discussion in 'Modding' started by LuitvD, 20 Dec 2006.
  1. LuitvD
    LuitvD What's a Dremel?
    13 Aug 2006
    I've seen many questions about charging Ni-MH and Li-Ion batteries, but I recently bought a Li-Po battery pack, and I wondered how I should charge it... What voltage I should use, the maximum charge current... I don't want to ruin a perfectly good battery :p
    about the Li-Po pack:
    Voltage: 7,4V
    Capacity: 2,2Ah
    Maximum discharge current: 10C/22A (continuous), 15C/33A (peak)
    I think the cells can be charged separately, there is an extra 3-pin connector, and I can't think of any other use... :D
    but what voltages, and charge currents... :wallbash:
  2. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    lithium Ion is actually easier to charge then ni-mh, it just is a lot more dangerous when done incorrectly :p
    it is typically done with a constant current-constant voltage charge. Constant current (.5C I believe, I would double check that, and all of this, I'm bringing it back from memory), and then once it reaches a certain voltage, it switches to constant voltage... once the current drops to a certain level, charging is complete.
  3. LuitvD
    13 Aug 2006
    that's lithium-ion.. is that any different from lithium-polymer? (and a constant-current of 0,5C is not much... would take 2 hours to charge completely then right?)
  4. ConKbot of Doom
    2 Jul 2003
    well a quick google and I found this...
    http://www.powerstream.com/li.htm
    :thumb:
    and yes, ideally, at .5C it would take 2 hours to charge... but allowing for the constant voltage portion of the charge takes time, also.
  5. LuitvD
    13 Aug 2006
    cheers, this really helped :)
    (should have googled some more I guess...)
  6. deiol
    deiol What's a Dremel?
    14 Jun 2001
  7. LuitvD
    13 Aug 2006
    wow, that looks nice :)
    cheers, sampling that product :D
