Cases Lian Li PC-P80 with Red Fans
Discussion in 'Tech Support' started by Bobinator2000, 6 May 2010.
  1. Bobinator2000
    Bobinator2000 I don't smell bad.
    23 Apr 2009
    I just finished my PC build and I have the aforementioned case. I bought the windowed side panel (too much of a pansy to do it myself...) and my RAM gives of some nice red light because of the activity lights on them, but the fans on the front and top are blue, which kind of looks ok if you look at it from the front (door closed = angelic blue, door open = eeeeeeeeeeevil insides >: D) but a bit silly from the side, through the window.
    I'm planning on putting some red LED strips inside the case to match the RAM but this would probably just make the miss-matched colours look a bit more odd...
    So my question is this: would these fans look ok in the front of the case and top? Also how good are Xigmatek fans? I have read good things but was wondering if any of you guys had any personal experience. I like quiet fans that sift a lot of air, and these seem to be them.
  2. bulldogjeff
    2 Mar 2010
    I've got red fans on top and blue in the rest of the case.If you get it right you'll end up with a nice purple blend in the middle when the light s hit the components.....Go for it m8
