I'm getting rather sick of this rattling/buzzing on my Lian Li. I think the main culprit is the locking bar for the side panels. Anyone know a good way to fix it?
1. Open case 2. Remove snake 3. Close case. Naah, frankly I'd get a piece of overhead paper and cut that to size and use as spacers, just add as many as you need.
Find whatever is making your case vibrate, either remove it or suspend it so it doesn't vibrate your case. I had the same problem with my V-1000 until I realized it was the pump that was shaking the case, and then I hung the pump from rubber bands. Presto, no more rattling lock bars.
