Scratch Build – In Progress Limey ------> update: 14 nov. - more building progress
Discussion in 'Project Logs' started by rambo, 4 Oct 2009.
  1. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    It's back - and it's wonderful!
  2. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    ...and i was almost typing "what ass r u talking about?" before i saw it... dunno if it's bad or if i REALLY like the case... :worried::duh:
  3. Cheapskate
    13 May 2007
    A distracting picture over a machine that could rip your arm off...:worried: At least she's over a lathe with a full guard.
    It's looking really good. I like the insets for the access panels. Most people working with fiberglass would add material until the frame fit. You went at it very differently.:lol: You still might want to add something to the middle points. This rig looks like a, 'hug to lift' setup, and that will cause a lot of stress on the shell.
    Are you going to add feet? If you place them just right, you could get this to look like it's floating. (-just a random idea.:D)
  4. Mr. Jay
    Mr. Jay What's a Dremel?
    4 May 2011
    It's a really good proyect man, it looks very well.
    Anyway, I was wondering if you could share de mobo support 2d drawings
  5. rambo
    rambo What's a Dremel?
    14 Mar 2007
    Hi thanks for the comments and sorry for the distracting women in the pictures I will try to keep them out of the pictures the next time. I just anodised the 2 back brackets because these will be glued to the case. By glueing it to the inner frame it will have extra support to the outer shell. In order to let this look smooth I need to glue the 2 brackets to the shell and Finnish the edges with plaster. If it is glued to the case I can't anodise it any more. The rest of the inner frame will be anodised as well but this will be done by a other company because it is a lot of work to do all the little things.
    Mr. Jay can you tell me what parts you exactly want to have and will see what I can do.
    No I am not going to make extra feet for the case I was thinking to put little rubber pieces just under the corners so it will stand on rubber in stand of the hard floor.
    The to pieces black anodised:
    Here are the 2 black pieces glued to the case with 2 component plaster:
    Keep on modding and See you next time, Julian
  6. rambo
    14 Mar 2007
    Hi, It is finally nearing completion so I got some new stuff to show you guys. After the process of sanding and plastering etc. Because I don't have a place or the equipment to spray paint the case myself I gave it to a Pay 'n' Spray shop to let them paint it in a lime and black color. Also I got some new hardware to put in to this case.
    First of I will show you how the underside of the side panel will stay in place.
    The 2 blocks in place:
    Inside view from the side panel when it is in place:
    Outside view from the side panel when it is in place:
    Yeh my case is back. Here I am trying to make the sound insulation foam to the correct size:
    Here you can see the sound insulation foam stuck in place:
    Front view of the case with sound insulation foam without anything else:
    Rear view:
    New hardware:
    1x black rubber frame for PSU.
    1x corsair H60 CPU cooler.
    2x MSI R6870 hawk graphic cards.
    4x nexus rubber fan hangers
    4x aero cool silver lightning fans. (1x92mm 2x120mm 1x140mm)
    6x black pci slot cover plates.
    2 New graphic cards and 1 is out of the box to show:
    the rest:
    I will be completing the case soon.
    Razer2007 likes this.
  7. Sheiken
    Sheiken Wat?
    9 Jan 2005
    Very unusual and very cool!
  8. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Very Very cool, and like Shieken said, unusual too.
  9. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    dam that's good!
  10. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    Truly professional!
  11. Cheapskate
    13 May 2007
    The green looks great.:D
  12. Moddingboy
    Moddingboy What's a Dremel?
    19 Jul 2011
    Awesome! :jawdrop:
  13. PureSilver
    16 Dec 2008
    Oh yes!
  14. alonso_bistro
    alonso_bistro I'm just looking
    19 Feb 2004
    I'm in love with your mod! :thumb:
  15. voigts
    voigts What's a Dremel?
    26 Apr 2006
    This is looking great. It is so stylish. I really like it.
  16. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    I really love the colour and shape! Can't wait to see the finished results.
  17. rambo
    14 Mar 2007
    Hi, thanks for al the compliments. I still need to do allot of stuff but it will be finished soon.
  18. kelmannen
    5 Feb 2011
    it's cool, very VERY cool! =D
  19. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Good to see some progress again on this! :D
    Looking great so far and nice to see you've got some nice hardware going in too.
  20. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    Okay, you have my attention :)
