Networks Linking 2 x PC does not work.
Discussion in 'Hardware' started by bradford010, 24 Jan 2002.
  1. vipmehta
    vipmehta What's a Dremel?
    11 Feb 2002
    Hmm...,
    PNP is more playing and less praying thankfully with Win2K.
    Short of trying out new drivers or different NIC cards. I am fresh out of ideas.
  2. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    Time to buy a new PC then. lol!:D
    I think a switch and some standard patch'll do for now.
  3. Medic6666
    Medic6666 What's a Dremel?
    28 Nov 2001
    I would have recommended a switch from the start. I have never even tried to connect pcs together with Xover cables..
    Switches are so cheap now that just for peace of mind, I would recommend them as the way to go.
    I have 6 PC/Servers set up and they all run through a switch that I got from work and all works fine.
    The only problem I had was the initial setup (was my first time :)).
    If a switch is out of the question then try getting NICs of the same make and model.
    Good luck
    Medic6666
  4. Vertekal
    Vertekal What's a Dremel?
    11 Feb 2002
    Is your xover cable wired correctly?
    one end should be wired in this order:
    12345678
    other end should be wired in this order:
    36145278
    If you temporarily install NetBEUI on both PC's, do they
    still not see each other? This would eliminate any issues
    with TCP/IP.
    Also, what services are running on each machine?
    Do they each have Server, Workstation, and Browser
    services running and started?
  5. bradford010
    7 Dec 2001
    BO!
    Doing nothing more than taking out the x-over and plugging the straight patch cables into the switch, the network now works without trouble. I know for a fact that nothing was defective except this ****ty OS!:rofl:
    Cheers for all the help here guys, even tho the original problem wasn't solved.
    If I can give one piece of advice to anyone considering linking two PCs, it's this. spend the extra bit of cash and save yourself a LOT of headaches get a hub.
