Networks Linksys Range Expander WRT54
Discussion in 'Tech Support' started by zhangmaster12, 12 Dec 2009.
  1. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    Hi, A client of mine is having problems with a Linksys Range Expander (at work, im pretty sure its WRT54 or something, but ill post name when I get back). I cannot get it to connect to the router and his computer. I followed everything in the instructions perfectly. Before I played with it, it was connected to the router, but it caused an IP conflict.
    Does anyone here have had problems with this range expander? If so, can you tell me how you fixed it?
    Heres what I did to connect it to the router:
    PLug into router.
    Access with computer at 192.168.1.240
    Change settings to match router
    Blue Link light goes on.
    Then move the expander downstiars.
    Blue link light on.
    Then Try to connect--> epic fail.
