Windows Linux CS Server??
Discussion in 'Gaming' started by Medic6666, 30 Apr 2002.
  1. Medic6666
    Medic6666 What's a Dremel?
    28 Nov 2001
    I have a redhat box that I have networked and all works fine.
    when I installed the half-life and CS server bits they all went ok as well.
    BUT!!
    when I tried to run the server using: ./hlds_run -game cstrike +maxplayers 4 +map cs_assault
    it starts going through a .pak file...this is taking about 6hours to run and then crashes.
    Anyone have any ideas on what I am doing wrong?
    cheers
    Medic6666
  2. Elspuddy
    Elspuddy Minimodder
    2 Oct 2001
    whats the speks of your linux box, and have you folloed or loked at counter server ???
  3. Medic6666
    28 Nov 2001
    speks
    its dell machine PII 333 with 200megs of RAM. A 20gig drive.
    Redhat 7.2 standard server build (i let the wizard install all).
    It is on my LAN and I can ping, telnet and samba is working.
    The machine is fast for everything apart from this.
    I used the counter server instructions for a linux server and thats how far I got.
    I am also getting a error about not finding country.cfg.
    cheers
    Medic6666
  4. Elspuddy
    Elspuddy Minimodder
    2 Oct 2001
    could samba be slwoing it down ???
  5. Medic6666
    28 Nov 2001
    will stop the service...
    I'll stop samba from starting and see what happens..
    Not sure this will solve it, but its worth a try..
    cheers
    Medic6666
