Modding linux firewall network mod
Discussion in 'Modding' started by scifikg, 21 Jul 2004.
  1. scifikg
    scifikg What's a Dremel?
    6 Oct 2003
    This is my secure firewall network and file server. Probably the most unique thing about it is the motion detection system. Any movement within about a foot of the controls will trigger a strobe alarm for about 3 seconds. Really it’s not much of a security deterrent, but it is good for freaking out unsuspecting individuals. :naughty:
    more pics and info here.
  2. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    DARN thats a nice case
    also nice toutch with the flames because its also a firewall
    i also see that you modded a hub/switch in your case
    also nice as server
  3. Go4t
    Go4t i
    13 Dec 2003
    that is sexy :dremel:
    how are the flames on there?
  4. Sord_Fish
    Sord_Fish What's a Dremel?
    30 Jan 2003
    nice work, i had seen the project log linked from x-s very good work looks very nice!!! :rock: also thanks for introducing me to smoothwall had to try it out when i read what you were running on it :D it rocks :rock:
  5. scifikg
    6 Oct 2003
    It is stained glass spray paint. I got it at a local craft store. I used a stencil to apply it to the lexan.
    [​IMG] [​IMG] [​IMG]
