Cooling Liquid cooling: Dust your radiator day!
Discussion in 'Hardware' started by SNiiPE_DoGG, 30 May 2010.
  1. SNiiPE_DoGG
    SNiiPE_DoGG Engineering The Extreme
    14 Apr 2009
    Just a friendly reminder to all the liquid coolers on this board to dust your radiators :)
    I just dropped my idle temp 10°C ! It looked like I had a small mouse in my hand with all the dust I took off :lol:
  2. DragunovHUN
    DragunovHUN Well-Known Member
    30 Oct 2008
    Prepare for nasty
  3. Combatus
    Combatus Bit-tech Modding + hardware reviews Staff Super Moderator
    16 Feb 2009
    Maybe you did! :D I'll be doing some dusting when my new rad arrives next weekend, I think the XSPC RX360 that's been in there for 6 months is going to yield enough muck to knit a jumper!:eyebrow:
  4. true_gamer
    true_gamer Well-Known Member
    4 May 2009
    I cleaned the heaps of dust out of my triple rad and around the fans with a hover before I fitted my water block to my HD5970. (To my loop)
    Simon
  5. bulldogjeff
    2 Mar 2010
    I've lost count of how many dead PC's that have come to me that have been killed by dust..
    Looks like you lot should get a Kim and Aggie in for a new show...HOW DIRTY IS MY PC!
  6. Krikkit
    21 Jan 2003
    Getting rid of the RX? Dibs?
  7. deadlyavenger
    deadlyavenger New Member
    6 May 2010
    I know it depends on how dusty your house is (?) but how often do you have to clean them? Is it just a case of attacking it with a brush/hoover until it's clean?
  8. bagman
    bagman Well-Known Member
    18 Apr 2009
    i don't have this problem as my rad is located at the top of my case so my board and grapcis card catches must of my dust
  9. Rofl_Waffle
    Rofl_Waffle New Member
    24 Mar 2010
    My Corsair 800D has an air filter so I get less dust. I alos have a real air filter for my room.
    The best way to clean dust is with a vaccum and gas compressor.
  10. Combatus
    16 Feb 2009
    Unfortunately not! Thermochill PA 120.2 and Phobya 240 yes though.
  11. pdf27
    pdf27 New Member
    6 Jul 2006
    Mine's inside the front panel of a Silverstone TJ-06. Turn the key, open the door and hoover it out every time I do the rest of the house :D
  12. logan'srun
    logan'srun following the footsteps of giants
    22 Apr 2008
    and that new rad is? Seems a shame to get rid of the PA. . . .
  13. Combatus
    16 Feb 2009
    A Phobya G-Changer 480 - replacing the two dual 120s!
  14. DragunovHUN
    30 Oct 2008
    Bump, just found a better picture of that rad.
  15. bulldogjeff
    2 Mar 2010
    YUK!!!!:jawdrop:
  16. Bakes
    Bakes New Member
    4 Jun 2010
    This is a somewhat unrelated statement (if by related you mean related to radiators), but today I cleaned out the fan filter on my power supply - it was amazing. Fan filter, completely clogged up with dust, can't see through etc. PSU, not a speck of dust in sight.
    I thoroughly recommend the fan filter as a way to reduce the amount of dust in your radiators!
  17. bagman
    18 Apr 2009
    what dust filter do you use then?
    i could do with some stopping dust getting to my psu and gpu
  18. Bakes
    Bakes New Member
    4 Jun 2010
    I have the dust filter that came with my case, the Cosmos S. It's just a mesh thing, but it's very effective. It's facing down as well so dust is unlikely to settle on it. Finally, because power supplies have horizontal exhausts, there's almost no chance of dust getting in from above.
  19. harrylimey
    harrylimey New Member
    5 Jun 2010
    That sure is a lotta fluff in there !.
    But as Quentin Crisp noted I find it does not get any worse after five years ! .
