Case Mod - In Progress "Little Angel" - * COMPLETED! - Final pictures pages 20 & 21 *
Discussion in 'Project Logs' started by xSoMBrAx, 8 Oct 2011.
What to do: Black or white tubing!?
  1. Black!
    26 vote(s)
    40.0%
  2. White!
    36 vote(s)
    55.4%
  3. No idea, I hate water cooling!
    3 vote(s)
    4.6%
  1. Winkston
    Winkston What's a Dremel?
    14 Aug 2011
    excelent working.
    And great PSU's btw.
  2. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Thanks! :)
    And yes, Seasonic PSU's are great :D:thumb:
    I've just recieved the hardware from Izar Micro, so after a year I can finally tell you what I'm going to put inside my Little Angel :D
    "Little Angel" Hardware List
    I will try to post also the final watercooling parts aswell :)
  3. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    The last radiator has been installed!
    I will add more detailed picture to show how the fans of that radiator are connected to the Aquaero.
    I think it looks much better with the little caps also give some contrast against the white.
    Getting close! :D
  4. Raikkok
    Raikkok What's a Dremel?
    2 Nov 2009
    Hey Sombra!
    Is there anymore to do it or just wait for the new superhard?
    See you :D
  5. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Hey Raikkok, there is still a lot to do I'm afraid...
    You always find something that doesn't match or something else goes wrong and you have to rethink the whole assembly hehe
    I'm having trouble with the Aquaero 5 + PA2 module + CD Drive + Top radiator setup.
    The top radiator goes all the way to the front and uses half of the 5 1/2 bay so there is not much space to connect everything.
    Also I need to connect the radiator with the AQ5 to watercool it and with tubing is going to be a very tight fit but all my loop depends on that connection.
    Today I'm going to show you the pumps I'm going to use for the setup:
    Swiftech Dual 35X with their new top
    Here is how I plan to connect reservoir + pump. (Please mind the foam... I'm not going to place it like that, will show you later :D)
    First thing I have to do is some custom wiring + sleeving
    What I'm going to do is connect each pump directly to the PSU. Each pump on different 12v rail...
    The other wires you see are for adjusting the pump speeds via PWM, and that will be managed by Aquaero 5.
    I will first bridge the PWM cables from each pump and then make a unique connection to the Aquaero, that way both pumps will work at same speed all the time (based on the Aquaero 5 settings)
    More soon...
  6. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    That block is RAD!
  7. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    The build is astonishing!
    Those Seasonic PSU's are class!
  8. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    :D:rock::D
    Yes, very well built and awesome performance (and heavy too! :D)
    I've been doing some sleeving to the 24 pins that are going to be plugged to the dual PSU starter I have.
    Check the picture but this is not going to be the final result, you will have to wait some time to see the end result :)
    Custom length wires ready!
    Each wire sleeved individually and because of the custom length of each wire the sleeving was a bit of a pain in the.... fingers. A lot of measurement going on! :waah::waah:
    Finally because of the personal way to start the PSU's I had to measure each wire individally since I didn't want end up having some short cables and other long cables once plugged into PSU and PCB.
    As already said, still waiting for some other parts to make all this more eye-candy hehe
  9. Guest-23315
    Guest-23315 Guest
    Im not a fan of individually sleeved cables, but very nice work on getting the wires the correct size, good attention to detail :thumb:
  10. samfgr
    samfgr techno : my life
    29 Jun 2011
    looks really good looking foward to new picture :)
  11. Nutman
    21 Oct 2008
    What is the alternative, if you want to sleeve e.g. the 24-pin ATX cable?
    :rock:
  12. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Thank you guys for the kinds words :)
    I've just finished sleeving the pump, so let me show you the "almost finished" product :)
    First thing I had to do was to solder extensions to the original wires and get rid of the molex type of connector since I'm going to plug the pumps directly to the PSU (Molex out, 6 pin connector in!)
    Green and blue wires are used to send the PWM signal to pumps
    To have both pumps at same speed at the same time I just had to connect the PWM wires in series.
    I also replaced the white connector with 4 pin black connector.
    This is how I decided to route the cables to the lower section and onto the PSU.
    I think they look good and will be hidden aswell :)
    Motherboard connections will also have black & vanilla color combination, just not sure about the pattern :)
    And this is how I left everything last night.
    I like the routing but needs to be improved, maybe will have to add some other clips to keep the sleeved cables stretched instead of this spaghetti style :D:D
  13. wratterus
    wratterus What's a Dremel?
    2 Jun 2011
    Awesome work with the sleeving, the PSU starter cables look great!
  14. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Thank you very much wratterus :)
    I think the dual PSU starter is one of the challenges I had during this setup (because of how do I had to sleeve and measure each single wire lol)
    Today It's my day off, so I'm already doing some work on the motherboard.
    I took some pictures last night, just wanted to share them with you :)
    The bullets don't look that bad once the board is installed but is something that I don't like and will have to do something about it...
    I will update later!
  15. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Looking great still.
    I think the best bet for the board would be to see if you can get water blocks to cool it if you don't, like the block's already on it.
    I cannot wait to see the finished result's though.
  16. amagriva
    amagriva Minimodder
    13 Jun 2009
  17. Nutman
    21 Oct 2008
    I don't think it's too bad with those bullets. Their colour matches the gold parts of the rest of the build and also the vanilla sleeving.
    But OK, if you still want to do something about them and if you can't get a water block (yet?) for the motherboard, how about if you simple painted the bullets black?
  18. Mizugetsu
    Mizugetsu What's a Dremel?
    12 Aug 2008
    I can't stand those faux bullets have you though about maybe adapting a Waterblock for the bit or
  19. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    I was hoping to have more options for watercooling the board lol
    Waterblock would be the only answer :D
    Thing is the bullets don't look that bad once you have the board at home, and also the color matches the build.
    I hope to watercool it anytime soon :D
    More updates from today!
    I've been doing some wiring and crimping today.
    This board has 2 4pin connectors instead just 1 as we can usually see in other motherboards.
    I think that it looks quite nice!
    Tomorrow I will finish the routing of cables and will crimp the other side of the connectors aswell.
    I still need to measure each wire so once connected they still look nice, and then jump to the sleeving!
  20. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    There are waterblocks for the MSI BBXPII, the mofsetblock is already done and out in EKWB store, the SB is soon finished ;D
