Electronics Little help with voltage
Discussion in 'Modding' started by Atarax, 12 Aug 2004.
  1. Atarax
    Atarax What's a Dremel?
    13 Jul 2004
    Ok, does anyone know if perhaps there is a 6 volt power lead from the power supply? if not is there a way that i can convert a 12 volt molex to 6 volt somehow? :confused:
  2. Firehed
    15 Feb 2004
    No there isn't one. 5v could possibly be close enough for your needs.
    I'd look for something like a cigarette lighter power adaptor and then wire that to a 12v molex lead.
  3. Emon
    Emon What's a Dremel?
    14 Jun 2004
    Um, resistor?
  4. Risky
    Risky Modder
    10 Sep 2001
    What is the 6V for?
  5. Skylined
    Skylined Minimodder
    3 May 2003
    Maybe speakers or phone...
    You can use a voltage regulator.
  6. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    I agree with the above poster, use a voltage regulator since depending on how much you are drawing, a resistor's rating may not be enough.
    Use either a variable voltage regulator or the 7806 set voltage regulator.
  7. Atarax
    13 Jul 2004
    Thanx fer the suggestion gang and you were right firehed 5v was enough. it turns out 5v is actually 5.16v and i guess that was enough to run it....it was a plasma ball btw :naughty: . maybe ill actually post this mod, maybe a work log too.... :idea:
