Networks load balancing in windows
Discussion in 'Hardware' started by Phil, 5 Oct 2001.
  1. Phil
    Phil What's a Dremel?
    19 Jul 2001
    Is there anyway I can have 2 network cards in my machine running on the same network, or in such a way as to double the throughput to/from my machine ?
    eg. I'm at a LAN party and I'm playing CS whilst simultaneously two or three people are leeching some mp3's from me - and I want to have windows automatically balance the load over the two NIC's for maximum throughput for example....
  2. Bursar
    Bursar What's a Dremel?
    6 May 2001
    Yes it's possible, but....
    You will need to have two identical network cards that support this load sharing facility. It's normally found in server class NICs, such as the following from Dabs:
    Encrypted Server Nic 168b 3XP
    Mfr code: 3CR990SVR97
    Quicklinx: 10XXWS
    £79.00 + VAT
    £92.82 inc VAT
    So not exactly cheap. It also means that you need two ports on the hub/switch. If you're going to an organised party (as opposed to your mates house), they might not be too keen to have you use more than one port. Or maybe they will, providing you pay extra for it.
  3. Ataraxia
    Ataraxia <b>OOH BABY!!!</b>
    12 Mar 2001
    putting the 2 cards on the same hub kind of defeats the point! you've then got 2x100meg going into a 100meg device!
    I think the easiest way to play games and still allow people to leech crap off you is to use an FTP program where you can limit the number of connected users and also limit their download speed. figure out the settings, leave enough bandwidth for gaming and you're set :)
  4. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    I wanted to do this as well, but its a bit exstreme not to mention exspensive.
    Just unshare your Mp3z when you are playing ;)
  5. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    i wish there was a way you could give privaledges to things useing hte internet, ei if you want to download something when your browsing the net you want at least 1k/s for the page and 4 k/s for the download ..... this is for a modem s you can tell with such low speed ;)
    NEEEEEEEEEEEEEED BROADBAND
  6. Phil
    19 Jul 2001
    A decent quality switch shouldn't hold them back, and I do have my own switch...so when I go to the LAN parties I normally own at least 50% of the network infrastructure anyway...
  7. RTT
    RTT #parp
    12 Mar 2001
    i think some download agents allow that mate.
    u can set the limit for the download, and anything else gets whats left over, sadly tho, most download agents are spyware and suck ass :(
  8. Ataraxia
    12 Mar 2001
  9. Evilbob
    Evilbob What's a Dremel?
    28 Apr 2001
    Reget version 1.8 is bestest no spyware and totally free!!!!
  10. Phil
    19 Jul 2001
    wtf is spyware then ?
  11. Forsaken
    Forsaken GameFaction.com
    27 Mar 2001
    sends useage data back to the company that made it, can be crap like sites u use
  12. Fly
    Fly inter arma silent leges
    31 Aug 2001
    gozilla and gator are two culprits...
    Fly
