Extensions to the USB, ethernet and audio ports At this point I extended some PC ports. Ethernet: USB (I used a 4 port hub): And 2 audio ports: one of them is always on, while the other is controlled by the mute button (one of the touch sensors):
Mounting the fans The two fans (speed controlled by one of the touch sensors) are placed over the projector, to generate a flow from the motherboard zone to the left tower: To mount each of them I used a steel bar and a bolt, to hang them on two roof joints: The hanging system: The fans were too big, so I had to cut one of the corners to fit them in place: And finally these are the fans mounted:
Photos of the assembled computer Now I can finally put the case outside for some photos: but there's one thing missing: a transparent "Lonherz Kernel" sticker: [Note from the future: I didn't like that sticker, so I removed it after a while] AND NOW A LOT OF PICS OF THE ASSEMBLED COMPUTER! Powered off, without flash: Powered off, with flash: And powered on at the twilight:
Painting and mounting the case feet I realized that I forgot one thing: the case feet! I previously cut and painted in grey 8 wood discs: To make a "metal" effect, I sprayed a little quantity of white paint. It was just the quantity to obtain little white dots on the grey background, so these drops seems like light reflections, as in a raw metal surface. This is the effect: This is the sequence: First the grey backround: Then the quick pass with white spray, to form the little white dots: I glue the felt pads: And this is the result:
Photos in the dark with projected secondary monitor Some pics in the dark, with the projector turned on, showing the secondary monitor:
Mounting 4 other cold cathode lights I thought that the case was not enough enlighted, so I added 4 other cold cathodes: two white and two purple. I have made the purple lights by myself, using white lights and a film of purple chromatic filter: First I moved another blue neon on the upper part of circuit encasing (so it is enlighted by 2 neons): Then I put the 6 blue led structure to better light the proximity sensor engraving: Here I complete the wiring of the two couples of neons: And here I put the purple neons under the PSU cover: The white neons must light the motherboard: One of them lights the motherboard from below: The other one is hidden behind the big PSU-motherboard cable, so it lights the upper part of the motherboard and the "acid green" transparent plastic wire that spires around the cable's tube: This is the effect on the cable's tube: And now some overview pics with the new lights:
Making a projection panel in polycarbonate After few months, I replaced the ugly plastic bag that I used as a projection panel, with a polycarbonate 2mm panel that I sanded with sandpaper. Then I made a sanded polycarbonate cover to hide the feedback LEDs:
and now, the mechanically moved thing that I said before... Making the “prankster bit” I added a thing to the case that I wanted to do from the beginning of the project! The device I wanted to make was a handmade mechanically moved object, that represented the final weapon of Tron 2.0: the "Prankster Bit". This weapon can be seen in this short video, and it is basically a purple glowing cylinder with some animated dark fins flying all around:
First I needed a slow electric motor to move a bicycle brake cable back and forth: I made it using a motor and some gears from my Lego technic stack: Then I cut some thin strips of polycarbonate: Then I took a bicycle brake cable, I removed the black plastic sheat, and I inserted it with an electric cable in a transparent rubber tube (so the appearance of this cable is similar to the structural joints). I glued with epoxy one of the brake cable's ends to two Lego pieces:
At this point, I started to work on the actual "Prankster bit": For the glowing cylinder I used this plastic graduated cylinder: I sanded it to make it translucent, keeping some parts transparent: Then I cut the triangular fins from an aluminium bar: I made some holes all around the cylinder (a hole for each fin), then I polished the edges of the polycarbonate strips: I drilled a hole on the strips ends: Then I opened this holes, to obtain a sort of socket to join the strips to a central shaft: And then I assembled all the strips on the central shaft (a threaded steel bar) in the cylinder: Now, you can imagine that moving back and forth the central shaft, all the strips will be moved accordingly
At this point I joined the shaft to the brake cable, and a purple cold cathode light to the electric cable: Then I polished and glued the aluminium fins to the polycarbonate strips: And finally two pics of the assembled and lighted "prankster bit", mounted in the case :
you might be , seems we share the same passion too , 'hope to have a chance to see some ogre's modding one day, it should be epic
Thank you both!!! During the work I have changed a lot of ideas, but one thing I wanted from the beginning was that my mod had to be absurd and unconventional at any cost...
