Equipment Looking for a camera
Discussion in 'Photography, Art & Design' started by stepea, 18 May 2015.
  1. stepea
    stepea What's a Dremel?
    13 Dec 2009
    Can anyone recommend a camera under £200
  2. MadGinga
    MadGinga oooh whats this do?
    19 Mar 2009
    if you can stretch to £250, i'd say this would be pretty darn good...
    We have the D5200 and its awesome.
  3. stepea
    13 Dec 2009
    I've looked at the Nikon's - I'm a very casual photographer, a half decent travel camera - something that takes better photos than a camera-phone.
  4. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    I use a Nikon coolpix and very happy with it. Excellent little camera
  5. stepea
    13 Dec 2009
    What model have you got.
    Digital Camera or Bridge Camera
  6. stepea
    13 Dec 2009
    anyone own coolpix 7000
  7. MadGinga
    19 Mar 2009
    If you're just looking for a casual point-&-click for travel, then the Fuji Finepix are great in my experience.
    Have used a compact, one with SLR-like functionality in a compact body, and the "bridge" type (SLR type body, but no interchangeable lens) and have thoroughly enjoyed using them.
  8. Kovoet
    26 Aug 2009
  9. Yadda
    Yadda Minimodder
    25 Jul 2003
    If you're looking for something that can produce great images but is small and easy to carry around/take on holiday, then the Fuji XF1 falls well within budget (about £130 if you hunt around). If you can stretch your budget a little then the Fuji XQ1 is worth a look (about £210 if you hunt around).
  10. stepea
    13 Dec 2009
    Thanks for the advice.
    Had a quick look at the XF1 but reading about lens control error which puts me off slightly.
    Quite like the XQ1, might be worth me paying the extra
  11. veato
    veato I should be working
    15 Jan 2010
    The Finepix S1 is a little bit more than your budget but has a RAW support, weather sealed and a long lens making it useful for travel. The HS50EXR is also worth a look.
  12. veato
    15 Jan 2010
    Saw some sample shots for the Pentax XG-1 today and for what it costs (£189) I was pretty impressed.
  13. angelicateets
    angelicateets What's a Dremel?
    1 Oct 2015
    Hello
    If you are looking a camera Canon PowerShot SX520 HS is best looks like any bridge camera
  14. JacobVR
    JacobVR What's a Dremel?
    6 Jan 2016
    I use The Canon and very happy with it. Excellent camera!
  15. mayallen
    mayallen What's a Dremel?
    23 Aug 2016
    I use a D5200
