Cooling Looking for a Water block for Reserator 2 "8800 GTX"
Discussion in 'Hardware' started by j.rhy@n, 7 Dec 2006.
  1. j.rhy@n
    j.rhy@n What's a Dremel?
    10 Feb 2005
    Hi
    I have a new Reserator 2 , the water block for the GPU doesnt fit. This has been explained by Zalman , but in the mean time I want to buy a seperate Cooler..
    Its for a 8800 GTX , becuase of mixing metal types what GPU water cooler could I use for my 8800 ?
    Tubing is 12 x 8 mm ..
    thx for any help..
  2. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    Could try the Aquacomputer 8800GTS Waterblock but i don't think the block has been released just yet... i'm sure there are connectors around which will be suitable with the reservator
  3. Krikkit
    21 Jan 2003
    I'd stick with aircooling for the timebeing mate - there'll be some WC blocks for the 88 series soon. Those two dies will be a bitch for any normal block...
  4. j.rhy@n
    10 Feb 2005
    Ye , Im sure Zalman will make one for it ... Im not sure if both dies have to be cooled...
    The main chip is massive..
    Here is my card with the Zalman cooler next to it..
    [​IMG][​IMG]
  5. Krikkit
    21 Jan 2003
    I suppose you could put a VGA-sink on the small die, then put a waterblock on the main die. That'd probably work nicely. (didn't think the smaller die had nearby mounting holes).
    :thumb:
  6. LoneArchon
    LoneArchon What's a Dremel?
    15 Jun 2004
    the power regulator also have to be cooled dangerden has their block out for it. It has g1/4 fitting holes so you should be able to find a connector for your tube size. Dangerden states there is 26 parts that need cooling
  7. j.rhy@n
    10 Feb 2005
    Ouch , but I dotn think Memory Chips need cooling unless your volt modding and alike.. May be Im wrong..
  8. Krikkit
    21 Jan 2003
    Well, if there's a DangerDen block out, I'd grab that. DD know their stuff. :thumb:
  9. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    although DD and low flow aren't too freindly.
  10. j.rhy@n
    10 Feb 2005
    At moment I can only find 2 , little expensive but I think I shall wait a little while to see what other companies bring to the market..
  11. Risky
    Risky Modder
    10 Sep 2001
    It appears to be available http://www.aqua-computer-systeme.de/shopsystem/product_info.php?products_id=1650
    Shouldn't be any problem getting fittings for the zalman - it's G1/8 thread.
