Other Looking for custom bootloader/OS Selection...
Discussion in 'Software' started by g2tegsown, 26 Mar 2012.
  1. g2tegsown
    g2tegsown What's a Dremel?
    28 Jan 2007
    Just wondering if anyone knows of a custom bootloader that would be capable of doing the following...
    Here's the setup I have a machine that has 3 hard drives, each hard drive has a different OS (Ubuntu, Windows and OSX 10.6). What I want to do is load a bootloader onto a flash drive and then have the machine boot to the flash drive. Then it would load a GRAPHICAL loader where I could select the "icon" based on the OS and it would boot to the correct hard drive.
    Does anything like this exist? I know GRUB can do something like this but it's not cool looking... And I want cool damn it lol
    Thanks for your time :)
  2. Comfyasabadger
    Comfyasabadger What's a Dremel?
    23 Jun 2009
  3. Byron C
    Byron C I was told there would be cheesecake…?
    12 Apr 2002
    I used to use the Chimera bootloader to select between OS X & Windows; it was actually part of the process of installing OS X on a PC.
    You mention that the machine has OS X.... Is this a real Mac or a "hackintoshed" PC? If it's a "hackintoshed" machine, have a look at the TonyMac blog - I think it's pretty much the "home" of this bootloader. If it's a real Mac, I'm not sure how you'd fare with Chimera...
  4. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    BURG. It can be a bit of a pain to install / get working correctly though. Its just a nice front end for grub2. If you spend the time to make sure grub2 is configured perfect first you will have a lot less problems. I would definitely advise making your linux disc primary and installing it there. Also installing through burg-manager rather than the base burg package makes things a lot easier.
  5. badders
    badders Neuken in de Keuken
    4 Dec 2007
    +1 - plenty of cool-looking themes for BURG IIRC.
