Peripherals Looking for good desk suggestions?
Discussion in 'Hardware' started by RagingMadman, 1 May 2017.
  1. RagingMadman
    RagingMadman What's a Dremel?
    6 Oct 2012
    Sorry if this isnt the right place to post this.
    Really looking for a nice desk upgrade. Currently have a **** desk that leave me cramped and my mouse runs out of pad too often.
    I would like to find maybe a 60w or better with 22d or greater.
    I'm not too picky. I can rage pretty hard so im not interested in getting glass tops again xD
    I learned my lesson. Furniture stores have **** for office setups with weird tops. I'm really looking for something simple but cant really find anything decent. Suggestions?
  2. MeMo
    MeMo It is what it is
    26 Jun 2016
    Sooo.. do you need drawers, shelfs?????
  3. RedFlames
    23 Apr 2009
    i'm guessing that's inches not cm...
    but...
    PC... on or under
    does it need to accommodate monitors? how many?
    then...
    sitting or standing?
    free-standing or integrated/?
    storage?
    preference on materials [other than 'not glass']
    Miscellaneous **** like do you need somewhere to bolt peripherals [like a steering wheel and/or joystick] to
    and all-important... how much are you prepared to spend?
  4. Gareth Halfacree
    4 Dec 2007
    I have this from Ikea, with a cable management shelf underneath. Cheap, massive, and can be used used sitting or standing. The only real drawback: it does wobble a bit in standing mode.
  5. MeMo
    26 Jun 2016
    I have the same one and it does work well, but yeah a little wobbly in the standing position, but not enough to interfer with performance, I would give it a 8/10. I am moving soon so I will probably pass it a long and get something else.
  6. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    I'm looking to go multi-monitor soon, so I've been eyeing up this one (also Ikea)
    It's not adjustable at all, and I might swap one of the drawer towers for a cupboard. (Cupboard is £10 cheaper)
  7. johnim40
    johnim40 Minimodder
    23 Apr 2009
  8. modd1uk
    modd1uk Multimodder
    4 Sep 2006
  9. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    It's a shame that Ikea have discontinued the Galant range as they were excellent desks. I'm not entirely convinced by the replacement range (Bekant).
  10. Behemoth
    Behemoth Timelord in training
    1 Nov 2001
    Even I couldn't cope with that mess ! That would drive me insane and I can usually cope with organised chaos.
  11. RedFlames
    23 Apr 2009
    It's tidy enough... i can still see desk...
  12. johnim40
    johnim40 Minimodder
    23 Apr 2009
    lol its my corner the misses keeps out
  13. Behemoth
    1 Nov 2001
    This was once how my desk looked.
  14. MeMo
    26 Jun 2016
    Nice!!! I know someone like that!!
  15. Behemoth
    1 Nov 2001
    That was almost 10 years ago, I've gotten a bit more organised since then lol.
  16. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    1) Get your chair adjusted properly (seat height set so your upper legs are parallel wit hthe ground, feet flat on the ground
    2) Lower your arms so your forearms are horizontal and your upper arms are close to pointing straight down (will probably be a bit off, whatever's comfortable for you)
    3) Measure how high your arms are above the ground. This is how high your desk surface should be to sit at it comfortably
    4) Get some cheap Ikea legs whose hight range is right for the height you need
    5) Get a big sheet of wood (either an Ikea desk surface or whatever else is available) and stick the legs under it
  17. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    I second the Ikea Galant. In my area there is lots available on kijji and ebay. If you don't mind second hand, they can be great computer desks. I got mine second hand and managed to match a straight section and two 45° corner pieces (not the nice L corners). I forget the total length but some where around 4 meters of desk. :D
