Looking for new CPU for folding!
Discussion in 'bit-tech Folding Team' started by ross2011, 8 Oct 2012.
  1. ross2011
    ross2011 folding for my daughter
    11 Nov 2011
    Hi all i currently have a 2500k but i'm looking to upgrade a ihave asus max IV-gene-z 1155socket, by budget will be about 300pound, it will be for folding and gaming (when i get time) any ideas on the 3770k ?:thumb:
    Ross
  2. megadriveguy
    megadriveguy Minimodder
    19 May 2010
    upgrading from a 2500k to a 3770k isn't a worthwhile upgrade in my opinion, save your money
  3. ross2011
    11 Nov 2011
    Then any ideas what wud
    Be Gud upgrade I'll have £300 to spend on CPU?
  4. Slowlemon
    Slowlemon What's a Dremel?
    17 Apr 2012
    Hi Ross2011
    The 2500K is a very good processor. The 3770K is a better processor, the question is whether it is worth the cost to you. An alternative idea would be to wait 6 months and get a Haswell CPU (next generation). The Haswell chip will not fit the 1155 socket but you will have 6 months to save up for a new motherboard.
  5. megadriveguy
    19 May 2010
    More likely around 9 months as haswell should be hitting sometime next summer
    Your only real upgrade cpu wise is a 3930k and a 2011 board but obviously your going to need more like 600 odd pound for that, I'd wait for haswell
  6. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    Or hit 80 posts and then try and get a second hand 2600k on the market place for around £150 and put a big cooler on it, then run it at 5Ghz. Will take you from around 15k PPD to 30k PPD.
    It also helps if you have high speed memory for when folding I find, I use the samsung 22nm stuff, 2x4Gb dimms and run them at 1866MHz (9-9-9-27 1N) @ 1.40v. Some units I am chucking out almost 36k PPD but average 30k.
  7. Shirty
    18 Apr 1982
    Hi Ross, as suggested in your other thread on the same topic, I'd recommend keeping the 2500k where it is, and building a secondary folding rig with the best second hand parts you can find for £300.
    As TaRkA suggests above, a cheap 2600k in a cheap mobo/case with the bare minimum extra expense will net you far more PPD than simply upgrading your 2500k would. Plus you'd be a proper hardcore folder having more than one rig doing the deed.
  8. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    I agree with Shirty. :thumb:
