I've been looking at slot loading drives, decided i want... problem is, all i find is biege pioneer ones. i dont have any probs with pioneer, just... i need a black one can anyone help? Note: if u know of a different one thats black plz tell, i dont mind if its dvd-rw or whatever, lol
you can always paint the cover of the drive....thats what i would do instead of buy something i dont really want because of the color http://www.zapwizard.com/Black_Faceplates/index.html ... there is an example looks like zap used vinyl dye he might give you some pointers if you asked nicley
Well you would only be painting the face plate. If you screw it up (which is pretty hard to do) just call them up and say it broke and they'll send you a new one...its just a piece of plastic only costs a dollar or two
yeah just take the face off and spray it or whatever and youre done...you might want to read someones guide first just to get an idea...but its a simple job
