Electronics Looking for specific logic chip
Discussion in 'Modding' started by c.cam108, 7 Nov 2008.
  1. c.cam108
    c.cam108 Minimodder
    14 Feb 2004
    Hi
    I'm looking for a specific logic chip but I can't find it anywhere.
    I need it to take a 4-bit input and select one of 16 or however many outputs depending on the input.
    Ie, IN: 1001 output 9 pulled high
    IN: 0010 output 2 pulled high
    Does this exist? I'm sure it does but I think I'm just looking for the wrong name.
    Thanks
    Colin C
  2. Dreamslacker
    Dreamslacker Minimodder
    13 Sep 2006
    They are called BCD to Decimal decoders. Try googling to find one that's available/ affordable.
    An example of such a chip would be the HCC4028/ HCF4028; another would be the 74HC42. These have 4 inputs (BCD) and select 1 of 10 output pins based on the binary code presented.
    edit: I forgot to state that the inputs are parallel. ie. you present the BCD over 4 pins. It's not serial logic where you send the code via a series of pulses over a single wire.
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Also look at 4514B, 4-Bit Latch/4-to-16 Line Decoder with Output Hi.
    I have one waiting to be a 16-LED Knight Rider. :lol:
    1-of-8 line decoder chips (eg, 74HC138 or 74HCT138) can be chained as in Bill Bowden's KR.
