Looking for upgrade suggestions
Discussion in 'Hardware' started by kuroidoragon, 23 Jun 2020.
  1. kuroidoragon
    kuroidoragon Minimodder
    14 Oct 2012
    My current Processor & motherboard is
    Intel Core i7 8700k Coffee Lake Socket 1151 LGA
    Asus TUF Z370-PRO GAMING
    If I was to upgrade my CPU what other Intel CPU do you suggest that is a upgrade from what I have without being stupidly expensive
    & if possible it needs to be compatible with me NZXT Kraken X53 ( I think its the 53 im not to sure)
  2. spolsh
    spolsh Multimodder
    4 Feb 2012
    Can't think of much (without spending silly money) - a 9900K would go in the board with an up to date BIOS and it's the same cooler mounting, but you've got to ask if the cost is worth the performance difference, - I'd say no, but YMMV. 8700K shouldn't be struggling yet, is it ?
    kuroidoragon likes this.
  3. silk186
    silk186 Derp
    1 Dec 2014
    In what tasks is your 8700k holding you back?
  4. kuroidoragon
    14 Oct 2012
    no not really struggling in anything I do anyway yet just wondering what my options are for the future
  5. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Basically just a 9900k really...
  6. kuroidoragon
    14 Oct 2012
    how much would you say a 2nd hand 8700k Intel i7 is worth (just the chip) what would you say is the range I should be looking at from lowest to highest ?
  7. Bloody_Pete
    11 Aug 2008
    £200-£250 perhaps, thats what ebay looks like.
