Loop with Immiscible Liquids?
Discussion in 'Watercooling' started by ChromAnomaly, 13 Nov 2013.
  1. ChromAnomaly
    ChromAnomaly What's a Dremel?
    7 Nov 2013
    I know, it sounds like a really dumb idea, and you're going to lose some heat transfer. But does anyone know if putting 2 immiscible liquids in to a watercooling loop works?
    My thought was that if I add a relatively small amount of something like mineral oil to a water loop, the turbulence in the blocks would keep it suspended in visible droplets. Could create an interesting effect with a bit of dye added to one or both phases, and shouldn't create sludge like the fluids with solid suspensions do over time.
    Biggest concern I think is that the oil would separate sufficiently to stick somewhere, or coat the inside of blocks, etc. The res would be a bit of an issue since the oil could float to the top, but I think I have a way to take care of that.
    Thoughts? Anyone tried something crazy like this?
  2. Nexxo
    23 Oct 2001
    Over time the pump may act as an emulsifier and turn the water-oil mixture into a sort of mayonnaise gunk. Just look at what happens in car engines when the gasket goes and radiator coolant gets together with the engine oil.
  3. ChromAnomaly
    7 Nov 2013
    Good point, I was more worried about the opposite problem and hadn't considered accidentally creating an emulsion . . . though I think with the elevated temps in the loop, the (relatively) low shear of the pump, and distilled water that an emulsion and least wouldn't be stable.
  4. Nexxo
    23 Oct 2001
    If you're looking for interesting looking coolants, just talk to Mayhem. He spends years developing this stuff and is a consummate pro.
  5. benji2412
    benji2412 <insert message here>
    25 Apr 2009
    If you're talking about the ones that look as if they have glitter in (poor description I know), then I can second that they look ABSOLUTELY AMAZING.
  6. RedFlames
    23 Apr 2009
    While water cooling isn't exactly a forte of mine, the thing that immediately springs to mind is:
    'There's probably a reason no-one is doing it...'
    Weather it's because the pump turns it into a mayo like goo as nexxo says, or just ends up floating on top/sinking to the bottom of the loop, if it was doable, it probably would've been done by someone somewhere...
    also +1 for what nexxo says about Mayhems
  7. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Aren't you basically looking for exactly this:
    As far as I'm concerned, Mayhem's coolants are just witchcraft. I can't wait to try out illusion or Aurora 2 when they're finally finished.
  8. Nexxo
    23 Oct 2001
    Funny you should say that...
    :worried:
  9. ChromAnomaly
    7 Nov 2013
    If everyone thought like that, there would never be new products introduced to the market. Besides, just because an idea isn't commercially viable doesn't mean that you can't make it work on a small scale.
    Erm, yes actually. Hadn't seen that yet, guess someone beat me to it . . . but it does mean that it's possible. And the fact that it's not on the market yet means it's probably difficult . . . And difficult + not on the market = I'm probably going to try it at home :D
    Yeah, I really like the pearlescent Aurora stuff, but the fact that it only has a 6-mo system life is a bit of a turnoff. That's what got me started thinking about a homebrew option.
  10. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Aurora 2 is permanent. It should be out soon.
    It would create an emulsion, it's been tried before. Aurora is more complex than it appears, believe me I know better than anyone. I still toy with the idea of making new coolants, but honestly I don't have the R&D budget he has and it takes it. A one-off for home is fine, and I often wonder about that for Knight's Rest but at the same time I know that if I hold out he'll get his Liquidmetal coolants to market. Still, it would take an awful lot of experimentation and materials science knowledge to get a workable coolant. That's not to discourage you-just to let you know that it's work. Honestly I think it would be nice to see someone put the work in.
  11. ChromAnomaly
    7 Nov 2013
    Will definitely keep my eye out for Aurora 2.
    And thanks for the info - no sense in repeating someone else's failed experiment. Do you happen to know what liquids you've seen create emulsions?
    I'm a chemist by training, and playing with this sort of stuff is the reason I mod. So don't be surprised if I try it regardless :D But knowing what mixtures aren't worth attempting will probably save me from frying a couple pumps.
