Memory Low profile RGb ram
Discussion in 'Hardware' started by kuroidoragon, 14 Nov 2019.
  1. kuroidoragon
    kuroidoragon Minimodder
    14 Oct 2012
    Is there RGB Ram that is low profile if so what do you recomend ?
    I assume the ram would have to be low profile because in this picture as you can see the pipes coming from the cooler are right next to where my ram is so I would guess non low profile ram might have a problem fitting
    https://cdn1.imggmi.com/uploads/2019/11/14/cd20bbbaa26bbd6cf5856191de7ae3d0-full.jpg
    I have a Kraken X52 radiator
    I have a Asus Z370 Tuff Pro Gaming Motherboard
    I have DDR4 Corsair Vengeance LPX
    https://www.corsair.com/us/en/Categories/Products/Memory/vengeance-lpx-black/p/CMK16GX4M2A2666C16
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Going by this it looks like you'll be fine with and RAM :)
    kuroidoragon likes this.
  3. kuroidoragon
    14 Oct 2012
  4. Bloody_Pete
    11 Aug 2008
    Thats just a dual DIMM kit, so easily. If you're planning on getting 2 though, I'd probably just suggest getting a 2x16GB DIMM kit, it'll make you life easier in a lot of ways!
  5. kuroidoragon
    14 Oct 2012
    but will it fit ?
    im guessing (so easily) means yes...sorry I am a bit slow & thick & I was loking for a straight answer :)
  6. Bloody_Pete
    11 Aug 2008
    No problem! It will as the two primary slots for dual channel RAM are 2 and 4, so you'll have an extra slot's clearence.
  7. kuroidoragon
    14 Oct 2012
    https://uk.pcpartpicker.com/list/d4LhgJ
    it says Compatibility: No issues or incompatibilities found. should that site throw up a ram clearance issue if there was one ?
  8. kuroidoragon
    14 Oct 2012
    not sure what you mean are you saying all 4 slots will fit with that ram with my kraken x52 in place where the pipes are?
    or
    are you saying just use 2 slots only as you mentioned two primary slots for dual channel ?
    can I please get a straight yes all 4 slots will work with that cooler in place with where those pipes are ?
  9. kuroidoragon
    14 Oct 2012
    okay I found out NZXT have a live web chat so I asked there
    Dominic
    All 4 sticks will fit. It will be a tight fit.
    But you can also rotate the pump so the tubing is on the top but the NZXT logo will be vertical.
    ahh ok didnt know that my dad built the pc for me but im glad that it will fit - would the pipes be pushing against the stick in that particular slot or will it only just miss it
    as you said it would be tight
    Dominic
    It will be barely pushing on it if anything.
