Modding Low-profile video card with internal VGA header
Discussion in 'Modding' started by Noah, 7 Aug 2005.
  1. Noah
    Noah What's a Dremel?
    8 Feb 2004
    Any exist?
  2. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    one posible thing to do is to look on newegg for low profile cards. You are looking for one that the vga header is connected with a ribbon cable like this one: http://images10.newegg.com/productimage/14-127-181-01.JPG But newegg doesnt seem to carry and lowprofile cards so you would have to mod the bracket. But that way you just unscrew the vga connecter and *BOOM* internal vga :rock:
    Ohh yeah thats a MSI AGP 5200 http://www.newegg.com/Product/Product.asp?Item=N82E16814127181 But I have seen pci cards like that too
  3. star882
    star882 What's a Dremel?
    19 Mar 2003
    Didn't Zapwizard use one for his Ammo Box PC?
  4. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    just get any card you want and solder on wires instead of the VGA connector.
  5. mattthegamer463
    26 Nov 2004
    yeah, but tahts hard, because the spot is so small, it would be near impossible to do unless your a super good solderer. i tried that with a old vid card once, did not work AT ALL.
  6. Zidane
    Zidane What's a Dremel?
    27 Apr 2004
    you could just get a vga cable, and loop it back inside the case. for a couple of monitors i have here the cable has a plug on either end, and the monitor has a socket (although, these two monitors have both vga and rgb inputs). or, why not just get a cheap vga extender cable and cut it shorter? hell, come to think of it, you could just nip into maplins (or your local equivalent) and grab a plug and socket and a few inches of ribbon cable and make one for a few quid.
    i dont think there is a card with ain internal vga header.... having a screen inside/on the case, is not really a common thing.
  7. Smilodon
    25 Mar 2003
    no problem at all. Just cut the legs of the connector (it's not like it's going to be used anyway) and desolder one leg at a time.
  8. mattthegamer463
    26 Nov 2004
    well, maybe i just suck at soldering. my iron is so old, i should really buy a new one.
  9. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    if you think that's hard try solder smd components with an ordinary solder. iv'e done that many times
  10. Smilodon
    25 Mar 2003
    that's not hard, it just doesn't look so nice. Depends on the size. 0806 components are a bit tricky. Wery easy to melt.
  11. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Thanks for the link... that is absolutly perfect for the mod that I am planning with the LCD display...
  12. LockmanX
    LockmanX What's a Dremel?
    8 Jun 2003
    I know there a bunch of 9600SE's that have what you're looking for.
