Electronics Luxeon question....
Discussion in 'Modding' started by Phire, 17 Jul 2004.
  1. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    you actually get pretty many incandescents for 100$ ;)
  2. Phire
    Phire Performance-PCs.com
    11 Jan 2002
    boo for yellow lighting :grr:
  3. star882
    star882 What's a Dremel?
    19 Mar 2003
    CCFLs!
  4. Smilodon
    25 Mar 2003
    halogen?... :p
    Anyway, i agree that a LED lamp is waaay cooler :thumb:
  5. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    A Metal Halide lamp would also give a nice white light
  6. Phire
    11 Jan 2002
    /me looks at 9 white CCFLS sitting behind him
  7. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
  8. lamcdonald
    lamcdonald What's a Dremel?
    1 Mar 2004
    Speaking of Luxeons... Has anyone had a Luxeon die on them for no reason? I was testing a 1W white a few minutes ago, and it suddenly went out. It appears to be totally dead :waah: :( I was running it off 12V, with ~160-ohms resistance, which should give an LED current of around 55mA, certainly not enough to blow it :eyebrow: Must have been faulty?
  9. coorz
    coorz Miffed
    25 Apr 2003
    Ouch that must have hurt :waah: . Did you use higher wattage (1+) resistors? 1/4watts won't do...
    BTW luv that avatar :thumb:
  10. SteveyG
    23 Nov 2002
    Was it heatsinked properly?
  11. lamcdonald
    1 Mar 2004
    It was running on 1/6th of full current, so it wasn't even beginning to get warm (without a heatsink) :(
    coorz: Thanks :D I'm using this avatar on a couple of different forums at the moment.
    I was using 3x 470-ohm 1/4Ws in parallel, which gives around 156 ohms. They were barely getting warm.
    I've come to the conclusion that the LED must have been faulty, I could run a standard 5mm LED on that voltage/current without burning it out! :/
