Motherboards M.2 prefitted issue
Discussion in 'Hardware' started by MightyBenihana, 7 Dec 2019.
  1. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
    I have just got a z390 Asus Strix mitx mobo. It already had stand off in both screw positions but when I put the drive in the inner most one causes the drive to bend a little. I tried taking it out by hand and then with pliers but the ting won't shift.
    Is this an issue? Has anyone experienced similar?Any help appreciated on this one guys. Cheers.
  2. spolsh
    spolsh Multimodder
    4 Feb 2012
    Pretty sure it should come out .. the one's in my crosshair board are all removable. Wouldn't really want to bend the PCB of the m2 drive and stress things. Is there any circuitry on th eback of the m2 that could short out ?
  3. MightyBenihana
    8 Sep 2011
    I will have to have a check. Yeah, bending these things is not something I like either.
  4. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    If its anything like the MSI boards i've come across, they use a small socket to remove the mount.
  5. MightyBenihana
    8 Sep 2011
    It might have to be that then. I don't have anything like that though I don't think.
