Case Mod - In Progress Mach 7 Fanthom
Discussion in 'Project Logs' started by terrierizer, 17 Sep 2011.
  1. terrierizer
    terrierizer What's a Dremel?
    8 Sep 2011
    Finished the cable braiding after 6 hours at the dining table.
  2. terrierizer
    8 Sep 2011
    love this picture of the Mach .8 fans
  3. terrierizer
    8 Sep 2011
    this is the latest picture of the hardware
  4. terrierizer
    8 Sep 2011
    I've added a black tinted cover to the psu and cables. Does anyone have any ideas as to what I may add to this cover? I was thinking of the EK waterblocks logo or my own business logo, or evan my forum name. I may evan just leave it as it is giving a stealth effect.
  5. terrierizer
    8 Sep 2011
    My Rampage 3 Exrtreme has just arrived back from the repair shop so I now want to finish this project and sell it on so I can fund my next project which will be a scratch built ROG themed pc built around the R3E.
  6. Device Unknown
    Device Unknown What's a Dremel?
    13 Jul 2011
    Fantastic work man. What separates a good worklog from a great one is the photography. Could I suggest practicing on your photo skills a little, you do your awesome work no justice by fuzzy and generally bad photography. I'm no expert myself but make sure you read the how-to on shooting worklogs. Again I am in no way referring to your great mod, just the photos.
  7. Zorndar
    Zorndar What's a Dremel?
    26 May 2008
    I second' this, the photographs have a poor quality, you would have more resonance with better once.
    Also I have to say the sleeving of the 24pin mobo connector looks a bit off. Could it be possible that the heat shrinks are not exactly the same size? I could be wrong and it can result from the perspective. I´m speaking of this picture. Also as "Device Unknown" already stated they are a bit too long. Normally one uses around 1.5cm and cut them all in one run to the same size, for at least one connector. So you have a much better end result!
  8. terrierizer
    8 Sep 2011
    Thanks for the advice, been practicing the photography this week so I'm hoping I can post some better photographs shortly. I was given some advice about the heatshrink so made all of the pieces 15mm as you said before fitting the psu back in the case. Just ordered blue braid for the gpu power leads so I can do them in black and blue. I'm busy with the internal acrylic panels at the moment. :dremel:
  9. kelvinb
    kelvinb BF3 Username - D0rmarth
    20 Sep 2011
    nice build i would go with the smokey perspex for the window well done nice build so far. I would agree with the pictures and Im sure there is a guide on the forums about the best way to take photos for build logs
  10. terrierizer
    8 Sep 2011
    My 2 year old decided to push the pc over yesterday whilst I had the fill cap removed causing serious panic but I think dissaster has been averted. On a lighter note Ive just been to look at various switches as I've decided to put a car door type light effect when the front door is opened which will shine 2 blue led's on the drive.
  11. terrierizer
    8 Sep 2011
    latest delivery from specialtech
    acrylic panel cut and shaped ready to go over the psu
    blu ray drive and CM Muskateer fitted
    acrylic cut waiting for assembly and a decision on how I'll attach it to the drive bays
    I've decided to change the 45 fitting for a 90 degree on the pump
    Coolermaster Mach .8 fans braided
    Temp probe has arrived
    decided on the tinted acrylic side panel, looks better now it's had all the finger marks polished off
    braided the gfx cables black and blue
    Looking good now, more pictures to come of it running.
  12. Imbloodyskintagain
    Imbloodyskintagain What's a Dremel?
    26 Oct 2011
    Nice looking system mate, just my luck ive not long bought a newly built system off ebay seller (paid cash outside of ebay) only for him to screw me over. Now to decide if i can afford to buy your system off you and sell/part out the one i bought.
    (The tosser removed duel tv tuner/samsung dvd writer and never forwarded the receipts for all the new parts which he promised to do AND since then hasnt answered his home or mobile phone :( )
    AND,
    Ive bloody just bought and paid for a gtx 560 ti 2gb gpu aswell (DOH!!!!)
    Must admit i always fancy a watercooled quite system.
  13. terrierizer
    8 Sep 2011
    Thanks, it has turned out a lot better than I expected. I thought it may proove a bit tough for me, aren't really that patient but it has been such a pleasure to build. I'm trying to find a friend who is good with cameras as I can't get the settings right. The smoked glass panels look amazing, I'm just trying to find more places inside for a couple more.
    If you do want to buy it let me know as I'll have to sell it to fund the next project. I have 2 more already designed. I'm aiming to add more pictures tomorrow.
  14. terrierizer
    8 Sep 2011
    The blue led's are magnificent but the next build will be around my Rampage 3 board so it will be red and black
  15. terrierizer
    8 Sep 2011
    Just a bit of tidying up to do now. Then I will take some killer pictures.
  16. terrierizer
    8 Sep 2011
  17. Imbloodyskintagain
    26 Oct 2011
    PM me a price mate,
    What about gaurentee's, original purchase receipts? Also How quiet is it and what temps at idle and underload Please?
  18. terrierizer
    8 Sep 2011
    I'll do that for you, I'm going to do away with the 'muskateer' and add digital temp monitoring as it's not accurate enough with the anologue display.
  19. Imbloodyskintagain
    26 Oct 2011
    ok buddy,
    I await your pm :)
  20. terrierizer
    8 Sep 2011
    Started fabricating the acrylic panel for my temp display when disaster struck, my b&q's own brand multi tool decided to die after 5 years service. If dremel want to furbish me with a replacement it would be very well apreciated.
