Macho Mini
Discussion in 'Project Logs' started by MrBean, 2 Nov 2011.
  1. MrBean
    MrBean Minimodder
    21 Apr 2004
    Hello Guys,
    Pretty excited about this one.
    How would you go fitting 8x hard-drives + a Crucial M4 SSD, a 140mm radiator, DDC pump, res, 450W PSU and Wade-8011 mini-itx into a Lian-Li PC-Q08?
    Easy, I would reckon.
    Check this space.
    As a teaser, the following components have been acquired, and running in test-setup mode in the box, aircooled, with Server 2008 R2 installed:
    Portwell Wade-8011 C206-based Mini-ITX board
    Xeon E3 1245 (3.30hz)
    2x 4GB Crucial ECC Ram
    1x Crucial M4 128GB SSD (for OS)
    1x Lian-Li PC-Q08(black)
    450W SFF PSU
    1x SuperMicro USAS-S8iR SAS Controller (to check operability in Server 2008)
    1x HP 8x SAS SFF Drive-cage, yes, the same as in Project Blackbird
    4x 74GB SAS Drives - this will make way for 8x 146GB drives in the not-so-distant future
    1x DDC 3.25 Pump
    1x SR1 140mm Rad
    Ek Supreme LTX CPU Block
    Various BP fittings
    7/16" Tygon tubing
    Will assemble with Watercooling components on the weekend, and post pics - won't take long on this one at all, everthing ready to assemble one mean mofo of a Xeon-based mini-itx FileServer :)
    @ Mods: Please move to Worklogs.
  2. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    I was not surprised at all until I googled for Lian-Li PC-Q08 after reading mini-itx lol
    Good luck and post some pictures or sketch with your fitting plan :D
  3. MrBean
    MrBean Minimodder
    21 Apr 2004
    Will post pics on the weekend, thanx Mate :)
    I never do a pre-plan sketch, I have it all planned in my head.....probably whe I sometimes take so long finalising projects, haha.
  4. Nexxo
    23 Oct 2001
    Pics of work in progress, or it isn't a project log... Moved to Modding for now.
  5. MrBean
    MrBean Minimodder
    21 Apr 2004
    @ Nexxo: I will post pics on the weekend, no worries.
    And it's a Worklog, I promise :lol:
  6. MrBean
    MrBean Minimodder
    21 Apr 2004
    Heya Everyone,
    Got lots done today, and will post pictures tomorrow. Nearly midnight here, and off to bed.
    Just a teaser - system up and running on water, going very well, and full-load, around 16-17 deg C better off on the cpu vs air. Not to shabby for a single 140 with fan running at 900rpm/16db.
    Got the drive-cage fitted too, psu relocated, lots of fun - but more tomorrow when I post the pics.
    Fun I had today :)
  7. MrBean
    MrBean Minimodder
    21 Apr 2004
    Ok, as promised, quite a few progress pics of this mod.
    Before we start off, a quick photo of the basic hardware under testing, I ALWAYS do this part before modding, as very often, you end up putting big effort into a specific mod, based on very specific hardware-bits, just to stumble at the last hurdle, due to a dead bit of kit.
    So this setup was thoroughly tested, and, as can be expected of a system based on an industrial bit of kit, dead stable. For those that don't know Portwell, well, they're a pretty big supplier of high-quality Industrial Motherboards - one of our process-control systems are based upon them.
    Here is the setup running the Wade C206 chipset-based Xeon server board - all mini-itx, with 8gb of DDR3 ECC Ram, and Crucial M4 128gb SSD:
    Over the years, I have gathered a formidable arsenal of Watercooling goodies, bits of hardware from a lot of suppliers, and one of them is the well-designed (well, I thought so anyway) Apogee-Drive from Gabe at Swiftech.
    This remains the only piece of hardware that I have ever been sponsored with (Thanx Swiftech!) and I decided to put it to good use. Before today, it was removed from its box only to appreciate its beauty.
    Ah well, in for a surprise then, is it :rofl:
    Taking it apart reveals it is the venerable 10W (blue-impeller) DDC pump, very easily modded to 18W unit - I won't do that for this effort though, as it is not needed/desired, as we have only a single 140mm rad, and one CPU block.
    and the other side:
    and a close-up of the pcb-side - if you want to convert it to the 18W-version, simply join the wire/pad on the right with the unconnected pad far-right.
    For those that read my BlackBird log, you'll remember that I fitted 2x DDC-325's to the Koolance RP401X2, and modified the original pump-housings to fit in the Koolance res -> of course, I later got the Swiftech pump-heatsink kits, and removed the original 325 housings, and kept them for later use....
    One would work well here, so let's dress up that pump then, shall we:
    and here:
    Neither the original Apogee-Drive, nor the modded 325 housing had mounting tabs, so I had to make a plan - still had one of these left:
    which was a rather nice mod for the DDC-series of pumps - I will replace this in due course with the Swiftech unit, but needed to get all hardware installed to make sure I have room for all my ideas.
    and
    Decided to get crafty with a hacksaw and file, and fabbed some mounting-tabs, which I bolted to the heatsink:
    working rather well as a make-shift mounting-mechanism:
    this would be married to the EK-140 DDC top with integrated reservoir.....
    and here:
  8. MrBean
    MrBean Minimodder
    21 Apr 2004
    Next was the Gelid Wings fan, replacing the original front intake fan, and mounting the rad the the (well-designed, on purpose Lian-Li?) front bracket.
    This must be by far the easiest and quickest fitment of a rad I had ever done. Painless.
    and here, all nicely fitted together:
  9. MrBean
    MrBean Minimodder
    21 Apr 2004
    Mounting the rad in its place, and playing with the pump/res, to see which orientation would suit best, and checking clearance with the original 5.25" bracket above, as this has toi be retained, as you'll see later:
    and the pump at the back, against the motherboard tray:
  10. MrBean
    MrBean Minimodder
    21 Apr 2004
    Ok, time to get nekkid, as I have to fit the HP SAS-cage in somewhere:
    Did a lot of thinking on this one, many ideas where I would finally mount the cage, and, as one of my very early requirements were to keep this mod relatively simple, with the minimum fuss/cutting involved, I decided it should go where the PSU would normally go - amazingly, the opening is just about perfect to mount the cage in - I will need to fab a bezel later, but that will be pretty simplet to do.
    Marking the holes for the first mounting-screws:
    and test-fitting - I used 3 rivnuts on the side of the SAS-cage, in case you wondered:
    looking good...
    and
    then, using temporary spacers, bolting the cage to the original PSU-mounting holes - had to drill 2 new holes on each mounting-tab on the SAS-cage, but that was very simple:
    and here, with a total of 7 screws keeping the cage in position:
  11. MrBean
    MrBean Minimodder
    21 Apr 2004
    Next up, drilling holes to bolt the pump down:
    again, a quick test-fit to see how everything stacks up:
    Next up, fitting the SFX 450W Silverstone PSU to...yeah, you guessed it, the 5.25" bracket - with this being a file-server, I won't need an optical drive, but, I can probably fit a slotload slimline drive just for kicks, the jury's still out on that one.
    The PSU should go in here:
    or does it....push a bit, shove it a little, a few jiggles, and yes, 4mm clearance to the top of the rails, which means it will just squeeze in under the top:
    and here:
    and here:
  12. MrBean
    MrBean Minimodder
    21 Apr 2004
    PSU will be mounted with the fan pointing down, and this was done by simply using the Dremel to cut, and dressing with files, a new fan-intake:
    and mounted in place:
    and a couple more:
  13. MrBean
    MrBean Minimodder
    21 Apr 2004
    With the reservoir mounted against the rear wall, and the motherboard, by original design, bolted directly to the side-cover, I had to make provision for a fill-port.
    Still had one BP bulkhead fitting from Project Blackbird, which will work pretty well:
    and here:
    of course, I had to drill the 5.25" plate too, to allow passage through it:
    The end-result is rather pleasing, and will allow quick, easy filling of the reservoir:
    and
  14. MrBean
    MrBean Minimodder
    21 Apr 2004
    It was time to re-fit the SAS-cage backplane PCB:
    and see how well the hard-drives would mount to the cage - went like a well-oiled machine:
    The drives are not yet powered up, as I have to redo the waterloop - need one or 2 elbow-fittings from BP, which I will order this week - after this, I would be able to properly route the tubing, to allow fitment of the SAS Controller:
    Here's routing the pump outlet to rad:
    and 'semi-final' connections to the CPU, et al:
    I leave you with this shot for now, as this is the config I have the system running in, doing several tests, and see how well it goes vs stock air.
    I am pleased with the initial results, as we have a 16-deg drop in full-load temp over air, with the system maxing out at 58 deg C running Prime95. This is with the same ambient conditions, and about 30 deg C outside.
    Very happy with the result, not done yet, but amazing just how well this system was 'designed' for quick and easy watercooling. Of course, don't forget the fact that I can now fit 9 2.5" harddrives to it :lol:
  15. MrBean
    MrBean Minimodder
    21 Apr 2004
    A small update - to simplify things further, I have decided to order 2 items from PPCS, and hopefully it the parcel will be here before the weekend:
    i) Coolgate 140mm Rad
    ii) Swiftech PMP-400 heatsink
    The PMP-400 heatsink will clean up the pump installation, as well as allow me to reposition it somewhat to further simplify tubing routing.
    Then, by using the Coolgate 140mm rad, I will accomplish 2 things -> get rid of the reservoir, as it has a fill-port on the top of the rad, so it wil effectively become a reservoir too.
    Secondary to this, with the additional ports on the in- and outlets, I can use one of the ports as a drain, with a BP plug at the bottom - so another small hole in the base of the case, immediately underneath the one port, and we have a neat drain-hole - to easy.
    Will keep you guys posted, thanx for looking, and keep those ideas coming!
  16. MrBean
    MrBean Minimodder
    21 Apr 2004
    Enough pics fer ya?
  17. MrBean
    MrBean Minimodder
    21 Apr 2004
    Hello Guys,
    Unfortunately, the parcel hasn't arrived, even though I paid over $48 for EMS service from the USA. I can bet my bottom $ it's sitting at AusPost, being delayed here in Melbourne.
    Jeesh, sometimes this just riles me, as I have so hoped to have it in time to finish the mod this weekend.
    Apologies, I will carry on with finalizing a few other bits and bobs, like soldering a more standard 10-pin Molex to replace the propietary HP one. I got the same footprint Molex male and female pcb connectors and plugs from Mouser some time ago.
    They are keyed different tp the original though, and matched pairs.... I could not find the correctly keyed Molex plug to fit the one on the HP SAS cage. A simple mod to do, so I will get that sorted, and start working on the PSU to prepare it to provide power to the SAS-cage.
    Keep you all posted :)
  18. Nexxo
    23 Oct 2001
    Hmmm... OK. :p
  19. MrBean
    MrBean Minimodder
    21 Apr 2004
    Thanx Nexxo ;)
  20. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    i dont like that you have mixed barbs with compressionfitting :(, everything else looks awsome until this point :)
