Thermaltake Magma Core - Thermaltake UK Modding Trophy powered by Scan
Discussion in 'Project Logs' started by F3nixMods, 9 Feb 2016.
  1. Vault-Tec
    30 Aug 2015
    Nice work man. The moose looks fabulous :)
  2. F3nixMods
    F3nixMods What's a Dremel?
    24 Jun 2014
    Thanks Tim :)
  3. F3nixMods
    24 Jun 2014
    Thanks Vault-tec, appreciated
  4. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Awesome stuff!! Love those custom thumbscrews! Well, until you painted them black anyway. :) That control center is slicker than pig poop! :rock:
  5. F3nixMods
    24 Jun 2014
    Lol. Thanks Bartacus, thumb screws are still to be airbrushed, want them to blend in with the external panels. :thumb:
  6. IceTouch
    IceTouch What's a Dremel?
    26 Aug 2015
    Nice work! It's fun to see new stuff mastered like that!
  7. F3nixMods
    24 Jun 2014
    Cheers Icetouch :thumb:
  8. Combatus
    Combatus Bit-tech Modding + hardware reviews Staff Super Moderator
    16 Feb 2009
    I'm loving those glowing hexagonal fan grilles!
  9. F3nixMods
    24 Jun 2014
    Thanks Combatus. Appreciated
  10. F3nixMods
    24 Jun 2014
    Update 5
    Apologies for the late update.
    Reality is that unfortunately sometimes challenges are thrown our way that make objectives harder to achieve.
    Let's move on to the long overdue pictures
    Pumps support finished
    and in place
    Time to block the Strix 970
    That backplate will have to be trimmed to size
    Done and started work on the actual backplate which will go on top of the original. Double backplate, doesn't get much better than that lol
    What do u guys think? I'm liking it, will tie in with the external paint job nicely
    Disaster, after a lot of work and whilst drilling the custom reservoir last hole it actually snapped, tryed to weld it together but due to the uncertainty decided that this will only happen at a later stage, most definitely after the deadline which means that won't be part of the competition :(
    Moving on to better things hopefully
    Let the cutting start...
    Who would say? Snow in April???
    Gonna take forever to clean up this mess
    Test fitting
    Sanded and ready to progress
    By then it was clear that I needed a helping hand. My lovely daughter came to the rescue ;)
    Detail pics of the texturing
    On to priming
    Black base applied, silver and red brushed
    Orange and yellow next
    Meanwhile the backplate was being clear coated
    and the front rad supports done...
    GPU in place
    Rads in place
    Just wanted to send a huge shout out to Shakmods for sponsoring those beauties for the build, will tie in really nice with the rest. Great looking cables
    Didn't really take many pictures towards the end as it was a struggle and marathon to get the mod finished in time, to aggravate things had a leak and probs with the motherboard. Oh well, mod on!!!!
    Final shots next​
  11. F3nixMods
    24 Jun 2014
    Final shots
    Just want to say that this is the final competition shots but that there will be some more in the future. Build is as finished as I could get it for the deadline but there will be things to add. Front grills, custom reservoir, detail work, lateral windows, etc
    Don't mind the long tubes on the thermaltake command centre side, they will be cut once the reservoir is fitted.
    Cabling was a task and a half, whoever is familiar with the rgb ring fans knows that they have 5 pin connectors, extensions don't exist as such had to all be done. No pics though as it was a last minute job. Props to my brother for helping with that
    Thanks bro
    Love this picture
    and this one...
    Can independently control all four sides of the internal lighting and 3 sides of the external, plus 3 rgb strips thanks to the thermaltake command centre
    That's it for now guys.
    It was truly a pleasure and honour to be part of this competition, plus the chance to compete with the other four guys a thing of dreams.
    Do hope that you enjoy magma Core.
    Funnily enough I was asked today if I liked the final result, my answer was:
    Wouldn't trade it for any other I've seen to date. Guess I am :) even though it's not completely finished
    Mod on!!!
  12. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Looks awesome man, great work! :rock:
  13. F3nixMods
    24 Jun 2014
    Thanks mate
