Peripherals Mains hum problem.
Discussion in 'Hardware' started by Mr_Mistoffelees, 29 Jul 2020.
  1. Mr_Mistoffelees
    26 Aug 2014
    This is a copy/paste of a question I have asked on What HiFi, in case someone here has any ideas. It's a problem I have no experience of dealing with because I've not had it before.
    My wife has an Asus Xonar Essence STX feeding a Sennheiser BT100 via a headphone extension cable, this sends to a pair of Sony WH1000-XM3s. I believe the cable is picking up a mains hum. We have tried to route it away from power cables but, with only limited success. The cable is the one supplied with the headphones, would a better cable, or a clip-on ferrite suppressor be likely to help?
  2. Mister_Tad
    27 Dec 2002
    Whilst I can't tell you how to sort it, I can offer some diagnostic steps.
    - Try the optical input on the BT100
    - Try the headphone out direct from the PC onboard
    - If you're powering the BT100 from a wall wart, try from the PC
    - If from the PC, try a wall wart
    - In either case, try a USB power pack
    I'd suggest the optical route anyway if you can - the DAC -> ADC -> DAC signal path across three separate devices as it stands now makes me twitch.
  3. Mr_Mistoffelees
    26 Aug 2014
    Thanks Tad, I hadn't thought about all the processing going on there. Optical seems like an excellent suggestion, guaranteed no hum. Toslink cable ordered.
    So much easier with wired headphones...
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    A friend has it with a macbook years ago, its something to do with the USB grounding I think, he isolated it and it went away.
  5. Vault-Tec
    30 Aug 2015
  6. Mr_Mistoffelees
    26 Aug 2014
    Optical cable arrived today, mains hum a thing of the past. :grin:
    Fizzban, Vault-Tec and Arboreal like this.
  7. notmeagain
    notmeagain Minimodder
    29 Jan 2009
    With the xm3's, if I plug them into my mixer they sound shite, but Bluetooth is just fine.
    What magic did you use to get it sounding good via wired only?
