Guide Making a glowpad - or, how I learned to stop worrying and love the router
Discussion in 'Modding' started by disco volante, 9 Apr 2003.
  1. Hmm_nick_Hmm
    Hmm_nick_Hmm What's a Dremel?
    13 Jul 2003
    Thanks a bunch. if i ever get around to making one i'll be sure to get some pics! and again very nice. but i still have a few questions.
    How did you mount the LED's to the plexi? and
    What kind of swich did you use in the film canister? i am sorry about the questions but i ust want to get all the facts straight so i can start it and finish it instead of starting , then stopping to ask a Q, then restarting ETC... thanks a bunch
    O:idea: :idea: :idea: :idea: :idea: :idea: couldn't you take and ordinary black mouse pad and rip the top layer of and reapply to the plexi?
  2. v2hja
    v2hja What's a Dremel?
    10 Aug 2004
  3. Rexxie
    Rexxie What's a Dremel?
    18 Nov 2002
  4. v2hja
    10 Aug 2004
    well i am quite lazy
    So the sensitivity is up :D
  5. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    I wonder how many people 'get' the title. :D Nice work, looks good.
  6. Kobalt
    Kobalt What's a Dremel?
    26 Aug 2003
    I did something similar :D it comes in green too
  7. mooglemodder
    mooglemodder What's a Dremel?
    1 Feb 2004
    How do you get a frosted look to the plexi? Im trying to make my friend a pad that has a lilly cut into it, sinc eshe likes lillies. Im not sure how to get the frosted look.
  8. Kobalt
    26 Aug 2003
    this has a plastic sheet that was on my other mouse pad, but i had time to experiment and just sanding with 150 grit works just fine so i guess if you make a "negative" of your design out of heavy cardboard, stick it on there with silicone or something that you can easily get off the plexi afterwards you can sand it and get the cardboard and silicone rubber off when it's all done
    OR sandblast it very gently :worried:
    If you just want the design, if you look at the stripe that's holding the frosted plasticyou can see that with the leds it kinda lights up so if you make your design out of a thin coat of silicone rubber or some kind of rubber glue under the pad it'll probably light up like those rubber feet or the glued strip :thumb:
    BUT you'll still need a sanding or something similar to what i have to make your op. mouse work :eyebrow:
  9. epidemik
    epidemik What's a Dremel?
    11 Sep 2004
    nice nice.!
  10. mooglemodder
    1 Feb 2004
    I found some stuff called glass frost, so im trying it to see if it works. =D
  11. Kobalt
    26 Aug 2003
    It should, if it is what i think it is, it's kind of a paint but with a reacton to air that makes the glass looks like when it's very cold outside with snowflakes patterns overlapping eachother. maybe the only problem you'll encounter is on the long run it'll scratch but you may try to clear coat it maybe :worried:
  12. mooglemodder
    1 Feb 2004
  13. Twellmann
    Twellmann Carnivorous Homunculus
    5 Jan 2004
    where's the pictures from the film roll :duh:
  14. Kobalt
    26 Aug 2003
    Thnx for the idea, i bought some and frosted my pieces of plexi that i use as light mod, they glow better with it, but now i have to put another led in :thumb:
  15. mooglemodder
    1 Feb 2004
    No prob, make sure you dont spray it like what i did, i got dust and drit on it, so it have a bunch of bumps, and i seen it halfway thur the drying and tried to clean it off, wasnt the smartes idea....
  16. Kobalt
    26 Aug 2003
    yeah, i've found that it works best with just 1 small coat about 8 to 10 in from the piece. the effect is better than sanding :thumb:
  17. mooglemodder
    1 Feb 2004
    saves time too =D
  18. Dwarfed ALIEN
    Dwarfed ALIEN What's a Dremel?
    25 Jan 2005
