Tips Making video from a series of stills
Discussion in 'Photography, Art & Design' started by Cthippo, 21 May 2016.
  1. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    I decided to try something new yesterday and set my GoPro to take a still image every 2 seconds while I drove across the mountains. The end result was about 2200 images which I want to form into a sort of video. The specific question I have is whether there is a best length for each still to be on screen, or if it's just whatever works. More generally, does anyone have any tips for doing this sort of thing?
  2. GeorgeK
    18 Sep 2010
    Not that I have any idea how to do this but you might want to work backwards from how long you actually want the 'video' to be. If each was on the screen for 1 second then the video would be nearly 37 minutes long. 0.1 seconds would give a video just over 3½ minutes long.
  3. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Effectively you're just talking about a slideshow with each image on screen for a very short amount of time. Even Windows Movie Maker should be able to do that (although I don't know how it'll cope with that many images)
  4. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    24 frames per second.
    You might be able to down to 15 fps but it depends on the images, interval etc.
    As for tips, try this:
    http://www.learntimelapse.com/
  5. SkiDave
    SkiDave Minimodder
    16 Mar 2008
    I've found GoPro studio pretty good at producing a video from the stills. You can set the framerate and either crop/scale down to a useful aspect ratio.
    File formats are a bit odd (CineForm, some odd variants on .avi and .mov) but you can then use the edit/export functions to produce an .mp4 file for use in your favourite editing software
  6. Cthippo
    7 Aug 2005
    After about 24 hours of my computer grinding on this (my poor abused laptop), I finally got it put together and, nah. I think the problem I was having is that the 2 second interval between shots is too long for a smooth final product. If I was going to do it again I would set the interval to one second or even half a second. It probably depends on what you are shooting. If it's a s4 hour time lapse with a stationary camera then two seconds would probably be fine, but for driving up a windy road, shorter is better.
  7. sonicgroove
    sonicgroove Radical Atheist
    16 Mar 2011
    Are we not just talking about a timelapse video here?
  8. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    Use GoPro Studio. Works a treat. Alternatively, Premier Pro can import the photographs. You can download and install the Trial software if needed.
    HTH
