Modding Maplin, blue leds
Discussion in 'Modding' started by icedfusion, 31 Aug 2001.
  1. icedfusion
    icedfusion What's a Dremel?
    31 Aug 2001
    Does anyone have the part number for the very bright blue leds from maplin? i.e >=1000mcd?
    I did a search for 'led' and all the blue ones were not that bright.
    thx.
    ice.
    ps. as a result of these forums i have spent alot at maplin,
    wonder if you should become affiliated withthem somehow?
  2. Darkhorse
    Darkhorse What's a Dremel?
    2 Jul 2001
    Try these at RS: 235-9922. Blue 2000mcd at 3.6v
  3. Dremel_Freak
    Dremel_Freak What's a Dremel?
    18 Mar 2001
    JA25C for the Maplin clear blue high intensity LED's, rated at 5v so u need a 470 ohm resistor if u use them on a 12v circuit.
  4. Darkhorse
    2 Jul 2001
    The reason I got the 3.6v led's was so I could just swap out the original case leds without having to mess with resistors.
    They will be slightly under powered from the mobo as it only gives out 3v, but hey even if it drops to 1500mcd still damn bright.
  5. icedfusion
    31 Aug 2001
    thx for the replies, gonna scour for some quality switches now the leds are sorted.
