Modding masking black case?
Discussion in 'Modding' started by PsychoI3oy, 2 May 2004.
  1. PsychoI3oy
    PsychoI3oy Minimodder
    13 Apr 2004
    well i think i've come to the point where i'm nearly ready to cut my actual case with my nazgul/balrog designs. but i have a problem.
    you can see here: http://forums.bit-tech.net/showpost.php?p=607035&postcount=26 that i used the standard sharpie method of marking off what was to be cut for the testing on my old steel case, but that won't work on the new case as the insides of the panels are black. anyone have any ideas how to cleanly and neatly mark off the area i should cut?
  2. Xipher
    Xipher What's a Dremel?
    25 Apr 2004
    I don't know exactly what its called, but they use the tape for masking areas for pinstriping on cars and stuff, its a very thin white tap, and might work. either that or just masking tape.
  3. PsychoI3oy
    13 Apr 2004
    yeah, that might be what i have to do, put the masking tape down, put the stencil on top, then cut off the masking tape. i was kinda hoping for something that wouldn't interfere with the dremmel, but now that i think about it, if i use duct tape it should really keep me from scratching the inside of the case >:) :dremel: (we need a duct tape smiley, too)
  4. richtea78
    richtea78 Guest
    Im not an expert or anything but am I right in that what you are trying to do is fill in the areas of the template so that you know what areas to cut out? If so could you not fill it in with something like tippex and then cut round it?
