Well the TC-4 is for sale. It has a 3/8" thich polycarbonate top. That should do should it not. http://dtekcustoms.safeshopper.com/18/125.htm?124 :dude:
What can I say! HOW CAN I GET ONE? No seriously "HOW CAN I GET ONE?" IMHO DTeK have taken the CROWN from DD Dangerous Den have some clever designs but too many peeps have had problems with the MZ3, they have thought makin pretty, blocks cheap was the water cooling solution for the masses..... U JUST KNOW DEEP DOWN, even B4 any tests this block is gunna blow em outa the water (pun intended) Why are DD offering reductions to customers to switch over to "Copper" tops? I keep coming across threads from all over the place similar to this http://forums.procooling.com/vbb/showthread.php?s=&threadid=3445 Now the "TC-4" Technically superior in high flow channel design CNC craftmanship at it's highest in conjunction with a PolyCarbonate Lid. What Next SilVER There is one major flaw - The name is a bit pants, errrm that's it! TiTch do ya know what grade of Polycarb has been used? may be secret
I don't, I ordered mine the day they launched. I spoke to Danny at Dtek and have to say went away with total confidence.
It looks pretty much like a cuplex from aquacomputer. Why doesn't someone come up with a cool new design? cu elemental
Elemental do ya meeeeeeeen this? I think the top is Plexiglass GS and the fittings are 10mm The channel design is very different could you interpret the specs for me (my German is ?) cheers
specs of the cuplex: - 52x52x18 mm(width x depth x height) - bottom is of 11mm thick copper, and at least 5mm thick were the channels are - top of 8mm plexi GS, which won't break and can resist UV-light (babelfish say: Break-proof and UVSTEADILY; is this right? ) - they come with plug-and-cool connector for 8/6mm hose or with normal connectors for hose with 6mm, 8mm, 10mm inner diameter I think the design looks quite similar. I'd like to see something new cu Elemental
Elemental, what makes this design different is that it has trubulators in the chanels to make high turbulance and velocity in the block without affecting system flow. So it is new....
OK, but I'd like to see a cooler with a completely new design. K4.1, spiral and cuplex are quite ok, but it's time for a new cool design. Just my opinion ...
I may buy one of these? Let me know how long it takes and how much if any duty. We need a UK reseller of these or is there? Looks like the dream
UK Reseller Spawny Tekheads are listed as a reseller? on D-Teks website BUT Tekheads hav no watercoolin stuff in at the mo I have e-mailed them to ask what the situation is, no reply Yet!
ummm so its a coper box with a plexi top...theres a million of those out there and cpulex wuznt the first one.....and the channel design is completely different....but there isnt too much u can do anymore....just so much u can do with copper....
